monkeyarms
posted on 12/7/15 at 04:15 PM |
Oil level question - J15 + 1.7 Zetec SE
I have Just done an oil change on my kit, first one since i swapped this engine in last year.
It has the 1.7 Puma engine, which takes 4.6l of oil with a filter change.
So i drain the old oil, put new filter on and put 4 litres in. Now check the dipstick to start topping up to get to correct level. Thing is, the level
seems to be about 20mm above MAX already. So i think it just hasnt had chance to settle yet.
I went for a drive and pressure is good, high on cold temperature then lowers a little when warm as you would expect. No noises, runs sweet and
smooth.
I check the oil level again next day, and sure enough it is 20 to 30mm above MAX
I am straining my brain to think of what could be happening here.
1. incorrect dipstick (too long)
2. some kind of air lock, in filter maybe?
3. ???
I have thoughts of taking the sump off to have a look, but want to avoid the hassle as i would propbably have oil leaks, and doubt if it would show me
much anyway.
After doing loads of oil changes in the past, this has me stumped.
Anyone got an idea whats happening?
[Edited on 12/7/15 by monkeyarms]
HowardB
posted on 12/7/15 at 04:21 PM |
Was the original installation at an angle and the kit upright, or vice versa.?
Howard
Nickp
posted on 12/7/15 at 04:22 PM |
Has it got a chopped sump?
monkeyarms
posted on 12/7/15 at 04:32 PM |
The engine is mounted same as it was in the Puma.
No chopped sump, it is standard engine setup dropped staight into my J15
monkeyarms
posted on 12/7/15 at 04:40 PM |
The 1.4 Zetec it replaced was in same position and oil level was ok.
Here is the 1.7 engine mid install.
adithorp
posted on 12/7/15 at 05:20 PM |
4.6 sounds slot for a Sigma. I thought they were more like 4.2. Are you sure the 4.6 isn't for a dry engine? ie. completely dry as in just
built/never run rather than drained.
http://jpsc.org.uk/forum/
monkeyarms
posted on 12/7/15 at 05:46 PM |
At only 4 litres it was over reading though, by a lot on the dipstick.
RichN
posted on 12/7/15 at 06:34 PM |
I have a similar issue with my 1.25SE in the RIOT. It's because the engine isn't level. It leans one way so all of the oil doesn't
drain out. I've tried levelling it using jacks and ramps.
For me, if the dipstick reads MAX then I don't worry about it.
Jenko
posted on 12/7/15 at 06:56 PM |
Don't worry......I've struggled in the past to get 4l into the engine.....assuming you've not changed or bent the dipstick, just go
with it........I did manage to remove about 1/2 a litre of oil from the sump even when it's drained.
MY BLOG - http://westfieldv8.blogspot.co.uk/
joneh
posted on 12/7/15 at 08:25 PM |
Don't suppose you measured how much oil you took out and noticed the level before?
monkeyarms
posted on 13/7/15 at 01:08 PM |
Ahh thanks Rich + Jenko, I was hoping it was somthing like this. I didnt realise the engine was tilted so far forward.
I will drain some out so that the level is just on MAX
Jenko
posted on 13/7/15 at 01:15 PM |
I've not noticed the tilt on mine, but a good pointt, but if you look at the sump shape it's a real bowl, ad I always suspected draining
it didn't quite get the dregs out from the bottom......
[Edited on 13/7/15 by Jenko]
750mc
posted on 16/7/15 at 11:05 AM |
Might be worth fitting a catch tank when its running?
lordbenny
posted on 1/9/20 at 05:08 PM |
Wow, I know this is an almighty thread resurrection but I have the same issue. Can’t seem to get more than 3.5 litres of oil in my newly purchased
J15 (1.7 Zetec S). The engine is flat, the sump or dipstick isn’t modified, I drained the oil on two different levels, on ramps and on the flat....I
can only presume, as did Jenko (the cars original builder), that the sump retains quite a lot of the old oil. The last thing I want to do is run the
car without enough oil in it but it does show MAX on the dipstick.
johnH20
posted on 3/10/20 at 01:38 PM |
Just come across this thread. Not sure what you mean by flat. The production installation angle on a Sigma ( Zetec SE ) is 11 degree rotation
backwards towards the exhaust side. I struggle to get more than about 4.2 litres in my 1.7 and it has the 'proper' installation angle. As
noted above I suspect the 4.6 litre figure is for a dry engine at first fill.
lordbenny
posted on 3/10/20 at 02:28 PM |
I’ve since discovered this....about 4 litres in mine!
nickm
posted on 3/10/20 at 07:32 PM |
Mine is the 1.6 Zetec SE the Haynes quotes 4.25 litres and if excluding oil filter 3.75 litres
Nick M
