andyace
posted on 6/12/04 at 09:00 PM |
Pinto Question
Hi, Just got the donor car at the weekend and having a look at the engine.
The car is a 1988 Sierra Sapphire GL 4 door saloon (5Spd)
The engine has got a '205' marking on the side of it. Would this make it a '205' block. I thought these only came with the
DOHC models, mine is a SOHC non injected pinto.
I feel that I have started on a never ending walk !!!!
Many Thanks.
[Edited on 6/12/04 by andyace]
keith2lp
posted on 6/12/04 at 09:08 PM |
Hi
Most 2 litre Sierras/Transits & P100's from late 1988 onwards used the 205 block in either carb or injected form.
Keith
[Edited on 6/12/04 by keith2lp]
andyace
posted on 6/12/04 at 09:24 PM |
This is an April 88 Registered sierra.
Is there any other way to tell the block type?
Also how do I tell what type gearbox it is?
keith2lp
posted on 6/12/04 at 09:39 PM |
Hi
If it has 205 on the block then it is a 205 block. As for the gear box it is probably a type 9 as I don't think the MT75 was fitted to the
pinto, it is easy to tell as the MT75 is an all alloy construction with the bell housing as an integral part of the casting.
The type 9 has a seperate bell housing and is of cast iron construction with an alloy tail housing.
Keith
Benzine
posted on 6/12/04 at 09:43 PM |
This is my 205 block 2 litre pinto and type 9 gearbox if its any help
andyace
posted on 6/12/04 at 09:59 PM |
Guess it is a 205 with a Type 9 then. Apparently from searching here the type 9 has reverse top left (push down).
Another question : Mine apparently only does LRP and wont eat unleaded. Can I bolt on a head straight from a SOHC injection (did all SOHC injections
take unleaded?) and pop carbs back on? If so how available are these? (If anyone has a spare close to me that would be good!)
Many thanks for your help. Andy
jollygreengiant
posted on 6/12/04 at 10:20 PM |
Unleaded shouldn't be a major problem. From 84 onwards ford mainly produce heads capable of running unleaded. I ran an '82' 2.0
unleaded for 250k as a taxi with no problems. Just required timing adjustment.
edit :-
As for fitting injection head the inlet ports are (inj) pear shaped and the (carb) round. So there is an issue with regard to getting a good seal with
the manifold. This has however been 'Discussed' at length in previous posts.
Enjoy.
[Edited on 6/12/04 by jollygreengiant]
andyace
posted on 6/12/04 at 10:30 PM |
Cheers JGG, coincidentaly just read your comments on an earlier thread on same subject, must do searches before asking in future.
As for post 84 heads being ok for unleaded does that apply for all after this year or certain ones. What I am trying to ask is do I need to worry
about sticking unleaded into mine?
Also going back to my original question on the '205' block on a non injected SOHC, would this also imply that the head was 'unleaded
capable' !!
Thanks Again, Andy
posted on 7/12/04 at 12:45 AM |
There are codes stamped on the head.
Next to No4 spark plug. Unleaded 2 litres are L, P, PP, R or RR. Mine is an 87 and has the L stamp on it.
DaveFJ
posted on 7/12/04 at 08:49 AM |
if possible you should find yourself an injection head, they flow much better than the carb type .
And yes the head is a straight swap although you may need to look at the timing etc.
any idea what you are looking to use for fuel ? most put on twin 40's or 45's but I have also seen some very good installations using the
orginal injection system.
If you really fancy going a bit wild and have some spare monay - you could always fit the cosworth head
there are a couple of very good books on tuning the pinto, well worth the outlay. I'm sure someone else will name them for me, as the names have
slipped my mind.
Good Luck
Dave
