Author: Subject: Pinto Oil Pump
Avoneer
posted on 8/12/04 at 12:05 PM Reply With Quote
Pinto Oil Pump
Sump of at the mo, shall I replace the pump or can you clean them out?
Fair bit of crystalised sh*t on pick up gauze (probably sump gaskey sealant).
Pat...
mookaloid
posted on 8/12/04 at 01:02 PM Reply With Quote
If the oil pressure was ok before, then it's probably ok - a new one isn't a lot of money if you want to make sure tho'
I got a new one off ebay for a tenner when I built mine.
Remember to put the distributor drive back in! - I didn't
jollygreengiant
posted on 8/12/04 at 05:14 PM Reply With Quote
If you do change it (or not even, if you've got it out) it is well worth changing the hex drive shaft.
Enjoy.
