Plunky
posted on 22/9/15 at 08:09 PM |
Zetec blacktop oil pick up
I have recently replaced the engine in my F27 with a blacktop Zetec engine. The engine has come with, what looks like a retro ford rwd sump. However,
on removal of the sump, there is no oil pick up fitted. My question is, will a standard oil pick up fit with the different sump fitted? Or do I need
to go down a different route?
Thanks,
Liam
posted on 22/9/15 at 11:41 PM |
Post a pic of the sump first!
big_wasa
posted on 23/9/15 at 07:03 AM |
Look on the Rf web site and you will see the pick up pipe for there sump is far from a standard pickup.
Paul Turner
posted on 23/9/15 at 08:38 AM |
Modified sumps require the correct modified pick up to work as designed. Problem is the plastic pickup standard on later blacktops, its simply not
possible to modify it and that is probably why there is no pickup with your engine.
Suggest you speak to Retro Ford if they supplied the sump.
SJ
posted on 23/9/15 at 08:45 AM |
Many blacktops come with a metal pick. The three engines I've had all did. They are easy to chop and weld to fit a modified sump.
Stu
[Edited on 23/9/15 by SJ]
Plunky
posted on 23/9/15 at 12:38 PM |
i have a metal pick up from my old silver top engine.
would this fit if modified?
is it simply a case of cutting it down and re-welding?
Plunky
posted on 23/9/15 at 12:39 PM |
details of the sump in this post...
http://www.locostbuilders.co.uk/viewthread.php?tid=190636
Paul Turner
posted on 23/9/15 at 12:45 PM |
Looking at the photo's I would not want it on my seven.
Suggest you get a proper baffled sump from Scholar (just as good as the opposition and cheaper - identical to the well respected Dunnell sump)
together with pick up and fitting kit for the Blacktop.
Then sell that monstrosity to a mug on E-Bay.
Paul Turner
posted on 23/9/15 at 01:15 PM |
I have a Silvertop metal pickup on my Blacktop. It needs work to make it fit but it does and works perfectly. It requires the angle of the mounting
plate modifying as well as the head modifying to suit the sump.
But as I said above get a proper sump form a well known supplier rather than using that Heath Robinson contraption.
SJ
posted on 23/9/15 at 01:20 PM |
By all means get a custom made sump as I'm sure it is the best bet, but FYI I just chopped the standard blacktop sump without adding any
baffles. I've never had any issues with oil starvation.
Stu
Paul Turner
posted on 23/9/15 at 01:28 PM |
Stu
But have you been on the track with sticky tyres?
A sump that works under those circumstances is way cheaper than a replacement engine.
SJ
posted on 23/9/15 at 01:44 PM |
Text
Stu
Yes, if you are classing R888s as sticky tyres. I've never used slicks though.
Clearly if you are building a really track focused car then do it properly, but from my experience it isn't needed for occasional use. This is
locost builders after all.
Also, a replacement standard engine is probably a similar price to the sump, but I take the point that you don't want to be swapping engines
regularly.
It really depends which end of the cost scale you are working on & mine is definitely at the cheap end!
Stu
Paul Turner
posted on 23/9/15 at 02:07 PM |
Mine is a Caterham but I am still in favour of keeping costs down. I am not one of those "fortunates" that can throw £40000 down and drive
away in a new motor.
My first Zetec was bought in 2001 for £150 out of a burnout and was fitted for peanuts but I did not skimp on the important parts, still using the
same sump and steel flywheel.
When I fitted injection in 2004 I fabricated as much as I could to not only save money but also get a better fit than many off the shelf solutions
provide. I made the throttle linkage myself, works perfectly and cost a few bits of alloy and 2 afternoon's in the garage, fits better than any
Jenvey or similar.
But doing things in such a way that failure is inevitable does not add up financially and whilst I enjoy working on the car during the summer I enjoy
driving it more.
Over the years I have seen some real carbuncles that the owners were proud of but in truth were worth nothing, at least with a well built car its
worth something if you have to sell it.
Remember the old saying, "if its worth doing its worth doing well". I do and in the long term its no more expensive, do it right and do it
once.
Plunky
posted on 23/9/15 at 02:25 PM |
What is exactly wrong with the one i have?
Would you not recommend the complete kit from RF then?
http://www.retro-ford.co.uk/shop/content/zetec-rwd-front-drop-wet-sump-blacktop-a002bt
the Scholar sump isnt far off of the price of the RF kit
http://www.scholarengines.co.uk/Lowline%20sump.htm
Paul Turner
posted on 23/9/15 at 02:28 PM |
No because that is not a suitable sump for a Seven type kit car. If you look at the Scholar sump it has a flat bottom to maximise ground clearance and
is correctly baffled. The Retro Ford one has a lower front section which will soon get damaged or worse.
Buy the correct part for the car you are building.
SJ
posted on 23/9/15 at 03:32 PM |
I can't tell from the pics but would certainly agree ground clearance for the sump is a big issue. You need at least 10cm between the lowest
part of the sump and the road, and even then you will have to be careful.
There is no reason why the sump you have can't be modified, but whether it is easier to sell it and buy a different one is up to you.
looking at the prices I'll stick with my home chopped one! My donor car, engine, carbs, ignition and exhaust cost about that much!
Stu
Plunky
posted on 23/9/15 at 09:01 PM |
Also, to add, the previous engine, which was a silvertop, had an almost identical sump fitted, in terms of shape and I don't think clearance is
an issue.
Plunky
posted on 24/9/15 at 03:13 PM |
Does anyone know of any Scholar/Dunnel sumps that are for sale?
