bob
posted on 12/12/04 at 06:10 PM |
Another zetec install Question
WATER RAIL
I've heard these are available ?
does anyone know where and how much ? Any links appreciated ?
Or what are the alternatives ? bodge home made i mean
bob
posted on 12/12/04 at 06:29 PM |
found this http://www.raceline.co.uk/zetecframes.htm
But i;m sure there are other options
stevebubs
posted on 12/12/04 at 06:30 PM |
All it does is bring the water outlet from the back of the engine to front.
Looks pretty and makes plumbing slightly easier in RWD applications but personally I think they're a waste for £150-£250 quid.
RaceLine and Retroford definitely do them (in the above price range, I think the Raceline one is the more expensive of the 2). Last time I spoke to
Dunnell, they were also talking about doing a kit.
HTH
Stephen
bob
posted on 12/12/04 at 06:38 PM |
Thanks steve
Yeah your right re the price and do i really need it,i'm sure i can get something made up that will do the job.
I'm just trying to price up the install,engines seem to be everywhere so they are no problem its the rest of the parts i'm trying sort and
ofcourse in the locost fashion too the water rail is one part i dont want to throw 150 quid at if i dont have too.
zilspeed
posted on 12/12/04 at 06:43 PM |
Just take an elbow onto a stright run to the front of the engine. That's all the fancy cast alloy job is doing. When we did it in the sylva, we
just strapped it to the NS chassis rail.
zetec
posted on 12/12/04 at 06:47 PM |
Have a look in my photo archive. I've used large bore plated copper tube to get the main thermo housing outlet to the rad, the smaller one below
is done the same in 22mm copper and goes to a "T" piece in the bottom hose. the outlet on the drivers side is again copper tube to another
"T" in the bottom hose. A double "T" section for the bottom hose can be got from Tiger and is for once well made and £20.
Dunnel say keep the standard Ford thermo housing as it works far better than anything else and cost is zero.
givemethebighammer
posted on 12/12/04 at 07:14 PM |
search through ebay and the small ads
I got my water rail for £30 from a guy breaking a DAX, seen a few since less than £100. The Westie folks seem to regularly change their engines, where
we at locost are getting into using the zetec (seems to be mostly pinto and xflow on here), the Westie folks seem to be moving from the zetec and the
Vaux XE to newer stuff like the duratec. All good for us, I picked up some cheap carbs with ECU, fuel reg etc cheap from a bloke on:
http://boardroom.wscc.co.uk/cgi-bin/ikonboard.cgi?s=2bf5c8b0a6ef6d9736e43d38c47f1f58
as he was upgrading to fuel injection.
good luck searching.
bob
posted on 12/12/04 at 08:07 PM |
Chees for that lads
stevebubs
posted on 12/12/04 at 08:18 PM |
Zilspeed,
Any chance of a few pics? I'm in the middle of putting a 2.0 blacktop into my Fury and the plumbing is one thing I have yet to start (Still
making my own mounts and modifying the sump).
Stephen
zilspeed
posted on 12/12/04 at 10:09 PM |
Sorry - don't have the car any longer and don't really have any pics any more. It was about 7 years ago we did it.
It really was as simple as wombling an elbow onto the stat housing followed by a straight length going forwards. These were joined by a section of
steel tubing as a joining piece. All held together by jubilee clips.
It worked - that's all
stevebubs
posted on 12/12/04 at 11:42 PM |
No worries - that was pretty much what I was planning anyhow.
Stephen
