Author: Subject: cvh engine block capacity
matty h
posted on 16/11/15 at 09:02 PM Reply With Quote
How can you tell the difference between the 1.6 cvh block and 1.8 cvh block.
Matty
theconrodkid
posted on 16/11/15 at 09:13 PM Reply With Quote
just above the oil filter you should find 16 or 18 cast into the block.
who cares who wins
pass the pork pies
matty h
posted on 17/11/15 at 04:50 PM Reply With Quote
I can not seem to find any marking around this area.
Is there any other way of telling.
Matty
Angel Acevedo
posted on 17/11/15 at 06:26 PM Reply With Quote
You may calculate displacement by measuring Bore and Stroke.
HTH.
posted on 17/11/15 at 06:31 PM Reply With Quote
Not sure I remember any FWD 1800s but the Sierra 1800 have a distributor cap mounted on the timing belt cover, the Escort etc 1300 and 1600 had a proper distributor on the flywheel end of the engine.
posted on 17/11/15 at 06:37 PM Reply With Quote
Only RWD blocks have engine mounting bosses cast into the block in symmetrical positions adjacent to the centre main bearing location.
matty h
posted on 17/11/15 at 08:43 PM Reply With Quote
Problem I have is the head is a 1.6 but logbook say 1849cc so not sure what the block is will check the rwd mounting points, I am right to think the oil filters are in different places.
Matty
SJ
posted on 17/11/15 at 09:50 PM Reply With Quote
IIRC the 1.8 CVH is something like 1769cc so looks like you may have an american block 1.9 cvh which I think was was a popular Escort upgrade at one point. Think that should be 1859cc though.
Stu
