bug1
| posted on 19/11/15 at 08:50 PM |
duratec on throttle bodies
Hi this is just a thought but is it possible to fit throttle bodies and run the standard ecu if the throttle position sensor is connected would the
ecu know and would it make much difference. I am just thinking in the spirit of locost.
Ugg10
| posted on 19/11/15 at 09:34 PM |
You will probably need an airbox and the maf sensor connecting to it aswell as the oem lambda sensor(s). Also you will need the key and transponder
and maybe the clocks to make the ecu work properly.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
Grimsdale
| posted on 20/11/15 at 08:59 AM |
maybe, but what would you gain? a plenum of some sort would be much easier and cheaper
