Author: Subject: Can anyone send me an Omex 2.0l Zetec turbo map please?
D4ENX
posted on 22/11/15 at 02:33 PM Reply With Quote
Hey guys and gals, so I'm having a few problems with the Omex 600 and struggling to get it to start for the first time, has anyone got a map they've used successfully with a 2.0l Zetec turbo build I could try.
I'm using Siemens 630cc injectors, no speed or knock sensor.
Please pm me if you can, Thanks in advance.
[Edited on 21/11/15 by D4ENX]
Ugg10
posted on 23/11/15 at 12:28 PM Reply With Quote
Have you contacted Omex directly. I emailed them with my engine details and they sent out a base map and connection details (Puma 1.7 with TB's and the VCT still working) within a couple of days even though I was using a second hand OMEX 710.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
D4ENX
posted on 23/11/15 at 07:23 PM Reply With Quote
I have mate but have had some difficulty getting the car started as it just cranks and nothing more, i waswondering if i hadnt dont something correctly to the map that i should of and if a tried and tested map might get me going if not i know its another problem. Im going to ring omex tomorow though and make sure i know what im doing.
jeffw
posted on 23/11/15 at 09:08 PM Reply With Quote
Did you try the map I sent you then?
big-vee-twin
posted on 23/11/15 at 09:55 PM Reply With Quote
Is your crank sensor working, no signal no spark.
http://www.triangleltd.com
jeffw
posted on 24/11/15 at 06:19 AM Reply With Quote
he sees 150rpm on cranking so the sensor should be working.
perksy
posted on 24/11/15 at 11:23 AM Reply With Quote
TPS set correctly for the map your using ?
Got fuel and sparks ?
jeffw
posted on 24/11/15 at 11:49 AM Reply With Quote
http://www.locostbuilders.co.uk/viewthread.php?tid=201375
There was another thread on this...
D4ENX
posted on 26/11/15 at 06:32 PM Reply With Quote
Thanks for the replies, I'll be checking everything this weekend, spoke to omex and they've sent me a non start ford which is basically a problem solving graph which should help allot, yes the crank sensor is working but no fuel or spark, and no I haven't tried that map Jeff but if this form that omex sent me doesn't work that'll be the next thing I'll try.
I'll make sure I update you all with what I find, ta
