Millworm
posted on 28/11/15 at 06:18 PM |
Cossflow fan switch thread
I'm using a crossflow thermostat housing on my racleine water rail and I assumed it be the same thread as my engines coolant temp sensor but
it's not anyone know the thread so I can get an adaptor made up? Cheers
CraigJ
posted on 28/11/15 at 08:00 PM |
I'm sure it's M22 x 1.5
That is the size I got for my xflow.
benchmark51
posted on 28/11/15 at 08:09 PM |
yes it is M22x1.5
RADIATOR FAN SWITCH FOR FORD ESCORT 1.3 1995-1997 VE709003
posted on 28/11/15 at 09:04 PM |
Probably don't need to get one made , it's likely to be available?
Brian R
posted on 28/11/15 at 11:02 PM |
Same thread as a vw. If you're running a polo rad or similar they usually have one or a bung at least in the header tank.
Millworm
posted on 28/11/15 at 11:11 PM |
Only adaptors are available in bsp not npt. I'm running a cossie rad as it's a sierra
posted on 29/11/15 at 10:22 AM |
Put a hung in the housing and get a heater hose fitting with the thread you need, probably cheaper than getting an adaptor made? Carbuilderssolutions
list them
[Edited on 29/11/15 by rusty nuts]
benchmark51
posted on 29/11/15 at 10:30 AM |
Just buy a switch, about £15 on ebay.
posted on 29/11/15 at 10:48 AM |
He doesn't want a switch , he needs a Coolant Temperature Sensor
Millworm
posted on 29/11/15 at 12:55 PM |
Cheers guys that's looks like what I'll do, yea it's a coolant temp sensor for the ecu, witch is also the fan switch as it's
ecu controlled anyway. I'll put it in the heater matrix hose as that's be free the thermostat where it should really be
