sdh2903
posted on 5/12/15 at 04:17 PM |
Fan control, switch or ecu?
Hi all.
I'm just about to order my alloy rad and the supplier has asked if I would like a fan switch supplying with it. What's the preferred
option for fan control? A simple switch or ecu controlled?
My car is an mnr vortx, mx5 1.8 engine which I'm 95% certain will have a small turbo hanging off it. Ecu is a megasquirt pnp.
blakep82
posted on 5/12/15 at 04:38 PM |
i would go for switch controlled (i prefer switches over ECU controlled stuff anyway)
at least if you have a hole fitted for a switch, you can use it or not, its your choice later down the line. if you want it ecu controlled, all you
need is an old switch to fill the hole.
id say have the boss fitted anyway
________________________
r1_pete
posted on 5/12/15 at 05:16 PM |
I'd take the switch, then you still have the choice whether to use it or the ecu.
gremlin1234
posted on 5/12/15 at 09:47 PM |
quote: I'd take the switch, then you still have the choice whether to use it or the ecu.
ditto
bi22le
posted on 5/12/15 at 10:34 PM |
Mine is currently ecu. I Will be making it switch and ecu this winter.
Please read my ring story:
posted on 6/12/15 at 08:12 AM |
Belt and braces? Have seen more than a few witches fail causing overheating so a back up system is a good idea
Ugg10
posted on 6/12/15 at 08:38 AM |
Ecu control with overide switch.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
