Jmg
posted on 16/12/15 at 08:02 PM |
Oil coolers
Have ordered a oil filter relocator kit from muzzys in the us for my zx12 powered autograss special.
Heard loads of problems of them getting hot so thought I'd fit a oil cooler to prevent any over heating, due to limited space the cooler will be
located above the engine will I have problem with oil draining back into the engine once it's turned off?
Will standard oil pump work ok with this kit?
mark chandler
posted on 16/12/15 at 08:56 PM |
Standard pump will be fine, make sure the cooler is mounted with the unions at the top to prevent it draining back.
[Edited on 16/12/15 by mark chandler]
