Author: Subject: Oil control piston ring query
Monty2556
posted on 3/1/16 at 06:47 PM Reply With Quote
Just about to rebuild my 1600 x flow and the new piston rings arrived today. I was expecting the oil control ring to be in 3 parts - two rings with a spacer sandwiched between them. What I've got is one solid ring with a circular spring inside it. Is this right?
posted on 3/1/16 at 07:12 PM Reply With Quote
Think mine was the same , just a different type from what you expected.
posted on 3/1/16 at 10:39 PM Reply With Quote
Yes this is correct. A cast iron oil control ring with expander spring is very common.
