Author: Subject: gbs zetec turbo build
bodyrepairsjon
posted on 13/2/16 at 06:28 PM Reply With Quote
im after sum bits for my gbs zero build.i need a 1.8 zetec flywheel. omex ecu and a wiring loom for car. mayb other bits water pipes etc.can any1 help me thanks lads
J donaldson
theduck
posted on 13/2/16 at 06:39 PM Reply With Quote
Be aware GBS have advised other builders the chassis will require extra bracing when going beyond 200bhp, which I assume you will be?
bodyrepairsjon
posted on 13/2/16 at 06:42 PM Reply With Quote
yea think il have to mate
J donaldson
furryeggs
posted on 13/2/16 at 07:30 PM Reply With Quote
I have a 1.8/2.0 clutch and pressure plate, 228mm diameter, 23 spline. brand new.
bodyrepairsjon
posted on 13/2/16 at 08:47 PM Reply With Quote
just after flywheel as il be using stage 2 clutch to handel extra power mate.thanks any way tho.
J donaldson
