Author: Subject: Fury Bonnet Height
FuryRebuild
posted on 26/2/16 at 01:16 PM Reply With Quote
Fury Bonnet Height
Hi All
My fury body is in storage whilst I sort out the chassis mods and one of the mods is fitting a dry-sump tank which is quite tall. Could a fury owner do me a favour and let me know how high the bonnet is, from where it sits on the chassis to where it rests on the bulkhead. Could you also get me a second measurement so I can understand where it curves in from the side and flattens out on the top. This should mean I don't end up putting the tank too far out to the side-rail and having the bonnet bump on it.
I'll then fit the tank lower down so that it can clear the bonnet.
Many thanks for your help, tape measure, and looking at stuff.
www.furyrebuild.co.uk
adithorp
posted on 26/2/16 at 02:22 PM Reply With Quote
LeMans or Classic bonnet? If classic, does it have the bulge?
My LeMans is 350mm from the chassis rail/sidepod the centre flat section is 450mm then slopes by about 50mm over the next 250mm before curving down (all those measurements taken just in front of the scuttle)
http://jpsc.org.uk/forum/
FuryRebuild
posted on 26/2/16 at 02:38 PM Reply With Quote
Thanks Adithorp. I'm le mans as well. I can work with that.
HowardB
posted on 26/2/16 at 07:43 PM Reply With Quote
Under wing
Under wing
Hope that helps too
[Edited on 26/2/16 by HowardB]
Howard
FuryRebuild
posted on 26/2/16 at 11:08 PM Reply With Quote
Top banana. You guys are true gents.
