Author: Subject: Temp cover for type 9 propshaft?
peter030371
posted on 29/3/16 at 12:38 PM Reply With Quote
I want to bolt me engine and gearbox together and drop them in the chassis to mark out various places to drill for wiring etc. On the advice of BGH my gearbox has been filled with oil long before I need it and I turn it over by hand every 4-5 weeks. When I tilt the engine/box to feed it into the engine bay all the oil is going to pee out of the gearbox.
I don't really want to drain it and then re-fill it again when it is back out so has anyone a good idea on how to fit a temporary (but oil proof) 'bung' to the propshaft end of the gearbox? I can see this job getting very messy very quickly other wise!
I know that a brand new type 9 from Ford came with a plastic came pushed into the oil seal at the end of the gearbox...and these now sell for silly money (>£30) on ebay from time to time
HowardB
posted on 29/3/16 at 12:46 PM Reply With Quote
I used a 35mm film canister, wrapped with a little tape to make it the correct od,. perhaps a pill bottle might be the right size as I imagine that 35mm film containers are getting rare!
hth
Howard
peter030371
posted on 29/3/16 at 12:57 PM Reply With Quote
Good idea......I think I might have one 35mm film canister in the loft in a random box I happen to shift at the weekend!
gremlin1234
posted on 29/3/16 at 02:46 PM Reply With Quote
would these fit?
http://www.amazon.co.uk/Kitchen-Rubber-Glass-Demijohn-Solid-THREE/dp/B002L9DID4
peter030371
posted on 29/3/16 at 02:52 PM Reply With Quote
Originally posted by gremlin1234
would these fit?
No it has to allow the splined output shaft to go inside it...hence a film canister might just work
