Author: Subject: Type 9 clutch arm pin
emwmarine
posted on 30/3/16 at 08:50 AM Reply With Quote
How do you get the clutch arm pin out and a new one in? I must be missing something obvious.
Building a Dax Rush.
posted on 30/3/16 at 12:55 PM Reply With Quote
Not sure if you're referring to the pivot point of the are or where the cable attaches to the arm. A brief search on here suggests you can drift the pin out, but again not sure if they're referring to same pin as you are.
snapper
posted on 30/3/16 at 06:38 PM Reply With Quote
It drifts out but notorious for not fitting back in well.
You can use some lock tight but I just tap and use a shouldered bolt
I eat to survive
I drink to forget
