Author: Subject: clocks
dave69isit
posted on 19/12/04 at 11:11 PM Reply With Quote
clocks
do i needa regulator to control power or can i get away with just fuseing them if i need one what is the best way to do this happy christmas to all
posted on 19/12/04 at 11:57 PM Reply With Quote
I don't quite understand what it is you want to achieve Dave... could you explain a bit more?
stevebubs
posted on 20/12/04 at 12:13 AM Reply With Quote
I'm assuming you're asking about whether the supply is good enough to run the dash gauges from or whether you'll need a regulator in there to control the voltage etc?
If you're running a standard car engine with alternator, you should be able to get away with just putting a fuse in-line and wiring them up - most alternators give a clean enough supply.
zetec
posted on 20/12/04 at 10:36 AM Reply With Quote
Most modern clocks are fine. I've got CAI/Smith guages which are OK, as are VDO. But earleir Smith guages do need a regulator. Check the donor if using older guages.
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
posted on 20/12/04 at 11:31 AM Reply With Quote
Fit old style capillary/bourdon temp & pressure gauges and you don't need any electrics except the tachowiring and instrument ligts.
dave69isit
posted on 20/12/04 at 11:46 AM Reply With Quote
clocks
im using old smiths clocks of a68 jag xj6have a regulator but dont no how to wire cheers
