marc_cowley
| posted on 12/5/16 at 09:54 PM |
Jag 3.0 v6 to rx8 gearbox
Have unfortunately noticed that my jag s type clutch cover is self adjusting, does this mean that once it's adjusted the fingers will be further
in the cover? I'm now at the stage where I can get the adaptor plate made up and I'm looking at 25mm thick but if the fingers are going to
move in and away from the release bearing it won't need to be this thick, I don't have an adjustment tool so will have to get one. Anybody
any ideas? Does anybody know of any non self adjust clutch covers that will fit the s-type flywheel? Thanks in advance.
C30 T5
40inches
| posted on 13/5/16 at 07:56 AM |
From memory, the springs on the adjustment fingers are full compressed on a new clutch.
If yours are fully extended the adjuster is at full length,so no more change in thickness
marc_cowley
| posted on 14/5/16 at 08:39 PM |
Cheers, mine look to be half way, have fitted it up again today and even the spigot bearing looks to be spot on, getting easier by the minute, just to
source a 240mm 23 spline 1" unsprung clutch plate now! Ha, cheers.
C30 T5
Ugg10
| posted on 14/5/16 at 08:53 PM |
2.8 xr4
NEW NATIONAL 3 PIECE CLUTCH KIT FORD SIERRA SIERRA SAPPHIRE XR4I 2.8 (82-85)
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
marc_cowley
| posted on 15/5/16 at 06:17 AM |
Thanks but they appear to be a spring plate which may hit the inside of my clutch cover, thanks anyway
C30 T5
Ugg10
| posted on 15/5/16 at 06:35 AM |
Try these, in the US but they may ship.
http://www.summitracing.com/int/parts/acl-6240008/overview/
http://www.summitracing.com/int/parts/acl-4240008/overview/
There is an rx8 240mm version
These guys may he able to get just the plate
http://srbpower.com/products/act-heavy-duty-6-puck-sprung-paddle-clutch-kit-mazda-rx8-240mm-03-11-zm8-hdr6.html
[Edited on 15/5/16 by Ugg10]
mark chandler
| posted on 15/5/16 at 06:58 AM |
http://www.mardigras.co.uk
These will get a helix clutch cover and driven plate made up to your spec, I had a 240mm 6 paddle sprung plate made with a 1" 23 spline centre
for my car, it cost around £150 from memory. Feels like an organic clutch with no judder but can handle 500lb of torque from memory.
Highly recommended.
CNHSS1
| posted on 15/5/16 at 07:47 AM |
+1 for mardi gras and helix
| posted on 15/5/16 at 01:17 PM |
The whole idea with the self adjusting cover plates is that the fingers stay more or less in the same place over the life of the clutch, unlike a
standard cover where the fingers gradually move out as the clutch plate wears (or inwards for a pull clutch). This gives a more consistent bite point
and pedal travel over the life of the clutch.
