hearbear
posted on 13/5/16 at 10:52 PM |
Engine and gearbox combo
Been building a Stylus for a while now but after surgery on both feet now have difficulty with the clutch when driving so looking at the possibility
of going automatic. So with this in mind wondering what engine and auto box you would recommend as a poss doner. Would be looking for a 4 cyl rear
wheel drive combo.
3.9Ltr SSC Stylus should be fun
owelly
posted on 14/5/16 at 01:48 AM |
Omega or BMW? Both are readily available in auto and are cheap as chips. Or MX5?
http://www.ppcmag.co.uk
posted on 14/5/16 at 06:59 AM |
Have you considered an electrically operated clutch? A mate had one fitted to his camper an as his wife doesn't like using a foot operated
clutch , it had a button on top of the gear-lever and worked really well when I drove it.
mark chandler
posted on 14/5/16 at 05:43 PM |
Another possibility is to fit a servo on the clutch, I presume you have a hydraulic clutch?
Just get a remote one and tuck it away somewhere neatly.
scimjim
posted on 19/8/16 at 08:16 AM |
measure your chassis first - auto boxes are much wider than manuals! I'm fitting an MX5 1600 and auto box to a scimitar small sports chassis -
beauty of this combo is the low compression engine you get with the auto - just right for a supercharger ![](/images//smilies/smile.gif)
hearbear
posted on 19/8/16 at 08:35 AM |
It should be OK as I have a RV8 with LT77 in at the moment will need to pull that and sell.
scimjim
posted on 19/8/16 at 10:05 AM |
Ah - ok, LT77 is pretty huge ![](/images//smilies/smile.gif)
MattD
posted on 19/8/16 at 10:26 AM |
Hi George
As said.... Omega V6 & the getrag auto to go with it... dirt cheap. or the obvious BMW options.
Why not convert the Rover to auto ?
Completely different I know but...
Thought a about a 4 cyl bike engine, with a cable clutch you hardly need to use & flappy paddles on the steering wheel ??
Matt
hearbear
posted on 19/8/16 at 12:26 PM |
quote: Originally posted by MattD
Hi George
Matt
Is the omega a rear wheel drive? Or would I need a box out of another car to go with a omega engine.
Slimy38
posted on 19/8/16 at 01:56 PM |
Omega is rear wheel drive, one of the last from Vauxhall I believe (if you don't count the monster VXR's)
Pojo
posted on 19/8/16 at 01:58 PM |
How about a Jag S Type, 3.0 V6, rear wheel drive and over half of them were built with Autobox. 240Hp stock. cheap as chips. Change the S type sump
for an X type, better shape. It is smaller, lighter and more powerfull that a stock or slightly modified RV8.
ian locostzx9rc2
posted on 19/8/16 at 02:01 PM |
Couldn't you get an auto box for the rover engine ?
bj928
posted on 11/8/17 at 05:48 AM |
new mustangs have 4 pot 2.3 duratecs with auto/flappy paddle set up, that would be trick
