sonic
| posted on 15/5/16 at 07:26 PM |
R1 carbs extra return spring
Hello
I have fitted R1 carbs to my 2ltr Pinto, the revs are not shutting down quick enough. somebody on here said they fitted an extra return spring.
What spring did you use and how / where did you locate it?
Slater
| posted on 15/5/16 at 09:37 PM |
This is what I did on my ZZR carbs. Works just fine.
[img]
  Throttle Return Spring
[/img]
CosKev3
| posted on 16/5/16 at 09:57 AM |
As above you can make up a return system using the secondary cable slot on the throttle quadrant.
Or on the R1 carbs you can just buy a throttle return spring from merlin motorsport and attach it to the choke rail on the R1 carbs one end,and around
the tab on the throttle quadrant.
I've done this and it works spot on
CosKev3
| posted on 16/5/16 at 09:59 AM |
[Edited on 16/5/16 by CosKev3]
sonic
| posted on 16/5/16 at 05:11 PM |
Thanks guy's
I bet it was a cow of a job to get that nipple in there Kev!
CosKev3
| posted on 16/5/16 at 05:17 PM |
quote: Originally posted by sonic
Thanks guy's
Yeah it was!!!
Changed it now to a soldered end which was easier,but still fiddly
sonic
| posted on 16/5/16 at 05:20 PM |
Thanks for the help mate
