Bluemoon
| posted on 16/5/16 at 07:49 PM |
Leaky header tank caps...
Hi All,
Pressure tested radiator cap -> failed opens early 0.7 bar (should be 1.0 bar) and once opens closes at 0.1bar!!!
Got two new caps first one worked for (pressure test) but after one heat cycle from run out now opens at 0.7 bar (First line cap), second one
(different design again First line) leaks even without running.
Any recommendation for good makes of pressure caps impression of the first-line one is not good??
Original one would be nice but it's a rover part.....
Dan
gremlin1234
| posted on 16/5/16 at 08:30 PM |
is it one of these?
http://www.rimmerbros.co.uk/Item--i-PCD100160
'Pressure Cap - Expansion Tank - Genuine MG Rover'
cliftyhanger
| posted on 17/5/16 at 07:07 AM |
Is it the old type caps? Land Rover Forward Control 2 1/4Ltr. Petrol Series IIA 1962-67 RAD CAP
I have had nightmares with those type (not the one pictured) with some just falling apart when delivered. Others have a poor rubber seal so when the
engine cools water isn't sucked back into the system from the unpressurised tank.
Best is to get a proper branded type, there are some about. Had success with a "Ring" branded one that must be 15 years old now....
Bluemoon
| posted on 17/5/16 at 09:14 AM |
quote: Originally posted by gremlin1234
is it one of these?
yep same type but i have the aftermarket part not oem.
Bluemoon
| posted on 21/5/16 at 11:05 AM |
is it one of these?
One on order so we will see...
| posted on 21/5/16 at 11:49 AM |
Common problem an MGF & MG TF forum guy who tested new X-part ones and found it wasn't much better but found the one Halfords sell was OK.
