Avoneer
| posted on 23/12/04 at 08:39 PM |
Best position for Pinto sump baffle
Hi guys,
Anyone any suggestions as to the best place for a 1" high baffle to stop corner surge?
Maybe a round one around the pickup or one diagonally across?
Pat...
Avoneer
| posted on 23/12/04 at 08:46 PM |
I think B will be best.
NS Dev
| posted on 23/12/04 at 11:35 PM |
The oil will tend to flow over either type, and it will flow away from the pickup pipe as easily as towards it if you think about it.
You want a horizontal baffle that "traps" the oil beneath it, keeping it near the pickup at all times. Dave Vizard's type of baffle
was a horizontal plate across the deep part of the sump with various drain holes in it swaged dowwwnwatrs.
No goog, to much cidre tttto type rite gnite.
Avoneer
| posted on 23/12/04 at 11:40 PM |
So would it be best to weld in a vertical (with a couple of notches in the bottom edge of it) as in pic D and then a flat plate over the deep part
(with a few holes drilled in it)?
