Author: Subject: Fitting an air box and remote filter?
posted on 14/6/16 at 03:16 PM Reply With Quote
I've decided I've got to do something about the intake roar on my bike carbs - it's louder than the exhaust when on full throttle!
At the moment I have a home-made air filter box over the front of my CBR600 carbs, as there wasn't enough room to fit a commercial filter without cutting the bonnet.
My thoughts were to make a similar box without the hole for the filter, but with a hose mount at one end. The hose would go off somewhere to a remote filter - type unknown at the moment. The problem is that there's very little room around the engine, and nowhere obvious to get cold, fresh air. I can't get past the radiator into the nose cone, as it's a snug fit.
So - any suggestions? Or examples of other installations? It's a x-flow, BTW (if you don't recognise it from the photos!).
Cheers...
[Edited on 14/6/16 by David Jenkins]
907
posted on 14/6/16 at 04:13 PM Reply With Quote
That's why I built a plus 4.
Room for a 4 inch duct down to the nose cone.
On a more serious note;
don't forget that a 7" x 1" duct carries just as much air as a 3" pipe.
Do you have an inch of room beside the rad?
Paul G
