axle
| posted on 25/6/16 at 05:09 PM |
Squeaky noise
Hi all
I get the squeaky noise from the front of my car it is like slipping belt , but the fan belt is pretty tight, this happens when I am doing above 60
MPH . I let car free roll the noise is still there I have checked everything nothing is loose. I am wondering if I need to have more air vent on the
bonnet and maybe this is just a air flow magnify itself at that speed.
Has anyone else had the same problem, do I need to create air vent on the bonnet?
Regards Axle
IVA passed 1st time thanks to the Forum members.
Ben_Copeland
| posted on 25/6/16 at 06:17 PM |
I get a squeak / whistle from a tiny gap under my wind deflector.
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
RichN
| posted on 25/6/16 at 08:36 PM |
Is it a wheel bearing that needs adjusting or replacing?
axle
| posted on 25/6/16 at 10:12 PM |
Thanks for the reply , no all the bearings are new, if i break the noise does not go away till the speed has dropped!
Regards Axle
benchmark51
| posted on 25/6/16 at 10:34 PM |
I had a squeaky noise too, but the divorce fixed it.
axle
| posted on 25/6/16 at 11:40 PM |
wish I could fix mine too!
Regards Axle
myke pocock
| posted on 26/6/16 at 11:52 AM |
Probably not this but have you recently fitted a new fan belt? I have had a squeeky type sound coming from particular designs of fan belt in the past,
usually those toothed type ones.
Slimy38
| posted on 26/6/16 at 01:32 PM |
When you say the belt is 'pretty tight', how tight is that? My donor MX5 sounded like it had a slipping belt, turned out the belt was
actually too tight. It might sound daft but loosening it slightly brought it back to normal.
It could also be a contaminated belt, it doesn't matter how tight or loose it is if the belt or pulleys have been in contact with oil.
axle
| posted on 26/6/16 at 04:42 PM |
Thank you both for the reply , the fan belt has been cleaned it was tightened gradually so it did not slip at thick over. I have tightened it so it
can turn less 90 degree and yes it the flat type.
Regards Axle
CosKev3
| posted on 27/6/16 at 07:56 AM |
If it still does it with the car free wheeling surely it can't be the belt?
Try driving it with the bonnet off,see if the noise is still there
axle
| posted on 27/6/16 at 08:02 AM |
Hi
Thanks for your reply.
I have tried that the noise does go away , but I do still hear slightly that makes me think the noise vanish because the wind at that speed is
masking , what do you think?
Regards Axle
CosKev3
| posted on 27/6/16 at 08:15 AM |
Can you try blanking off the nose cone and driving it for a short while?
Will just be a case of eliminating where the air is making the noise.
Have you got any type of seal/foam tape etc where bonnet sits on the nosecone?
axle
| posted on 27/6/16 at 08:58 AM |
Hi there
I did blank off the nose cone and taped the gap with other panels , and made no difference!!
Regards Axle
Chris_Xtreme
| posted on 27/6/16 at 02:02 PM |
I'd double check the bearing tightness if you haven't already. I tightened my rear bearing up and got rid of a squeak.
axle
| posted on 27/6/16 at 06:12 PM |
Thanks for the reply,
I have already done that, the noise is from the engine bay. If I break the noise does not go till the speed has dropped below 50 MPH. I think I will
have to take it to a rolling road.
Regards Axle
Chris_Xtreme
| posted on 27/6/16 at 06:16 PM |
very bizarre !
you sure you aren't just over worrying? RR will be a lot of money to deal with a squeak. you hear everything in these cars.
owelly
| posted on 27/6/16 at 06:33 PM |
Can you establish if the noise is engine-speed related, or car speed related? I have seen many folks fight with squeaky belts only to be told it was
the exhaust manifold gasket that had failed. This would be an engine-speed dependant noise.
http://www.ppcmag.co.uk
axle
| posted on 30/6/16 at 06:48 AM |
Hi there
Thanks for the reply very interesting, I had to think about this carefully. Yes the noise happens when I am at above 60 mph and noise is a bit like a
squeaky belt.
However I checked round the exhaust manifold could not sign of smoke I also checked the gap with filler gauge there was no gap anywhere.
I had to tighten one of the bolts on the manifold,I have not manged to take out the car out for a drive yet.
As for the engine speed dependent noise could this be anything else as this started to become noticeable when the car was back on the road this
year?
Thanks again
Regards Axle
