Plunky
| posted on 2/8/16 at 07:07 PM |
Blacktop Zetec Timing
Evening all,
Does anyone local to Waterlooville have the tools/knowledge to check/re-time my blacktop zetec engine?
Beer funds available...
Liam
| posted on 2/8/16 at 07:21 PM |
Cams or ignition?
Plunky
| posted on 2/8/16 at 07:26 PM |
Cams
| posted on 3/8/16 at 03:32 PM |
Take the rocker cover off, turn the crank to tdc on number 1 and put a piece of 5mm bar through the slots at the back of the cams. The slots are
slightly off centre so will only fit one way.
There's a tool screws in the side of the block under the breather if your struggling for tdc.
| posted on 3/8/16 at 06:59 PM |
If you find the cam timing is out DO NOT using the timing bar to hold the cams while you undo the sprocket bolts, I've seen a few cams with
lumps out of them using this method. Use a sprocket holding tool
Plunky
| posted on 3/8/16 at 08:20 PM |
Thanks for the advice!
Is there nobody local that would kindly like to offer some assistance?
I've not played around with timing and engine before and don't fancy cocking it up!
