ande
| posted on 3/8/16 at 06:09 PM |
engine seems jammed
Hi, recently fitted a 1360 xflow in place of the 1.1, was having trouble getting it to fire up, but after discovering the timing was 180 deg out and
we had the wrong spark plugs(duh) we finally got it to run, but as the starter got slower due to running the battery down, it became stuck, well this
is what we thought, kept trying the key and just clonking. i got fed up with it and went out for the day, when came back, i tried it and it turned
over, but today it did it again, i have a starter on the way because i assumed it was the starter getting jammed, so i took the old one out today and
rocked the car back and forth in gear but the engine wont crank over! i don't know why because i was rocking it back and forth earlier to bring
the timing mark round on the pulley, but now it wont move, i have taken off the rocker shaft, just incase it's that getting jammed, but no,
taken the dizzy out, don't know if it would make a difference, but at this point i'll try anything.
gremlin1234
| posted on 3/8/16 at 06:18 PM |
does the car rock back and forth with
a- clutch depressed
b- out of gear
Slimy38
| posted on 3/8/16 at 06:20 PM |
Are the plugs in? You might just be rocking against cylinder compression. Especially if you've removed the rocker shaft as you'll have
closed all the valves.
ande
| posted on 3/8/16 at 06:31 PM |
Hi, the car will roll back and forth freely with the clutch depressed or out of gear yes.
Plugs are out.
| posted on 3/8/16 at 06:36 PM |
Sorry but it really sounds like it is seized solid. If it were water in the bores it would rock back the way You have removed the starter so it is
not that.
ande
| posted on 3/8/16 at 06:41 PM |
it did it the other day though and has been running since
| posted on 3/8/16 at 07:08 PM |
If the engine won't turn at all it does sound like its siezed, does the crank move at all or a few degrees? When you rebuilt the engine did you
check the size of the crank bearings both inside and outside diameter? Fords used oversize outside diameter main bearings which can catch people out .
If the crank turns a few degrees it could be a siezed piston ?
joneh
| posted on 3/8/16 at 07:23 PM |
They also did with the cam bearings as I just found out! I now have a 1300cc paper weight. Grrr.
ande
| posted on 3/8/16 at 07:43 PM |
i just went back out and re fitted the starter motor and it turned about 6 or 7 times, slowly but it turned over, then stopped again.
leon51274
| posted on 3/8/16 at 08:42 PM |
I'd be checking the battery first.
ande
| posted on 3/8/16 at 09:12 PM |
new battery, i just went out again, turned the key and it turned slowly, so i kept the key turned and it got a bit faster then faster and faster until
it was whizzing over at full speed, then it kept doing it then each time, it was gradually slowing down i think due to the battery draining, but if i
waited a few seconds it would whizz round again. i know this is a daft question but the alternator belt couldnt be too tight could it???
leon51274
| posted on 3/8/16 at 09:39 PM |
Could be.
Are you using the old inertia starter motor? Is the ring gear meshing nicely?
Have you tried twisting the alternator a bit while cranking the engine over to see if it turns over a bit quicker?
Just going off memory of starting issues i had with my crossflow although that was a few years back!
| posted on 3/8/16 at 09:57 PM |
Is there oil in the engine?
If yes, you should see it come out the rocker shaft if it is at correct level and oil pump working.
ande
| posted on 3/8/16 at 09:58 PM |
i have a new starter on the way, i dont think it's the starter though because we couldnt rock the engine over even with the starter removed
earlier, just been back out to it and it is whizzing over again, so would you say i can rule out seizing? daft question i know, as it isn't
seized at the moment, but thats what it feels like when it's jammed
ande
| posted on 3/8/16 at 10:00 PM |
couldnt see any oil coming out the rocker shaft, filled it with fresh oil 2 days ago
olberj
| posted on 3/8/16 at 10:07 PM |
Got a good earth on the engine/box?
ande
| posted on 3/8/16 at 10:08 PM |
yes mate but this oil thing has got me thinking now, no oil coming from rocker shaft, i bet thats what it is, oil pump!
snapper
| posted on 4/8/16 at 05:42 AM |
Earth strap?
I eat to survive
I drink to forget
theconrodkid
| posted on 4/8/16 at 07:52 AM |
with plugs and starter out can you turn the engine freely with a ratchet on crank bolt,any easier with foot on the clutch ?
sounds like something has come adrift inside the engine,crank thrust washer maybe ?
who cares who wins
pass the pork pies
Bigheppy
| posted on 4/8/16 at 07:57 AM |
Have you removed the fan belt. The alternator or water pump could be seizing. Long shot but easy to test
ande
| posted on 4/8/16 at 08:34 AM |
took the fan belt off and pump and alt are spinning free, now it's turning over again i can turn it with a spanner yes
ande
| posted on 4/8/16 at 09:56 AM |
Think i solved the problem, oil pump wasn't working, just fitted another one and i now have oil pumping out the rocker shaft, which i
didn't before, my engine is probably knackered now i wouldn't have even thought about it if 02gf74 on this thread hadn't
mentioned it so thanks, just crossing my fingers now that it isn't screwed.
[Edited on 4/8/16 by ande]
ReMan
| posted on 4/8/16 at 11:28 AM |
Oh dear!
Fingers crossed you may be lucky
www.plusnine.co.uk
ande
| posted on 4/8/16 at 11:58 AM |
ye hope so
ande
| posted on 6/8/16 at 08:06 PM |
what's the worst that could happen if i carry on using it then?
