johnemms
posted on 10/8/16 at 08:19 AM |
Toyota 3sge beams blacktop
This offers loads of power and 6 speed box .. just looking...
191 kW (260 HP) at 6,200 rpm Normaly Aspirated
Engine Specs
Toyota 3sge beams blacktop motor engine with 6-speed transmission wiring ecu
Toyota Avensis
Toyota Caldina
Toyota Camry
Toyota Carina
Toyota Carina E
Toyota Celica
Toyota Corona
Toyota RAV4
Toyota Vista
Lexus IS200 / Toyota Altezza
Own chassis & Build - First time pass!!
"7's" aren't really "cars", they are 'experiences"
posted on 10/8/16 at 09:05 AM |
They are pretty rare engines, in the UK at least.
johnemms
posted on 10/8/16 at 11:29 AM |
Ahh .. better the Honda 2000 then ..
SPYDER
posted on 10/8/16 at 02:24 PM |
Cut and pasted from your link...
4.5. 3S-GE Gen 5 (1998 – 2005) is the fifth and the last 3S-GE generation. The 3S-GE Gen 5 type is known for its usage of a Dual VVT-i variable valve
timing technology. The valves are similar because of their applying with the 3S-GE Gen 1-3 engine. The type’s power is 200 HP.
Besides, the type with a manual transmission have the different cams, titanium valves, compression ratio was increased up to 11.5, enlarged 35 mm
inlet valves, and 29.5 mm outlet valves. The power of such a type equals 210 HP at 7,500 rpm. with a torque equalling 220 Nm (162 lb•ft) at 4,800
rpm.
They come up often enough on ebay in the UK but they are tall engines and the gearbox is quite large.
I have the vanilla 16V 3SGE Gen 3 in my car but fitted with the six speed box like the one in the auction.
If I was starting again I would use the Blacktop in a heartbeat.
