jrod
| posted on 15/8/16 at 08:50 AM |
Duratec oil leak
I know Oil leaks have been covered before but can't seem to find anything relating to where mine is coming from.
It appears to be from the front cover.
Will taking this off involve re-timing?
mackei23b
| posted on 15/8/16 at 03:52 PM |
Yes you'll need to retime if it is a standard crank without a keyway.
The bottom pulley is friction fit as standard, to refit good practice is new friction washers and crank bolt, circa £25 a cam timing tool here:
https://www.toolstoday.co.uk/sealey-petrol-engine-setting-locking-kit-ford-mazda-volvo-1-25-1-4-1-6-1-8-2-0-2-3-16v-duratec-belt-chain-drive?gclid=CMf
hpbPjw84CFcky0woduXwDNg
Ian
jrod
| posted on 16/8/16 at 08:17 PM |
Thanks Ian,
A job I'll save for winter in that case.
Tools ordered in preparation
| posted on 17/8/16 at 07:45 AM |
I is worth trying adding some Engine Oil leak fix and 500ml of mineral first. Fully synthetic oil should have additives in them (plasticisers) to
keep the oils seals from becoming dry and brittle and shrinking but not all synthetic oils have plasticiser in the additve package and not all
plasticiser additives work with all seal materiels. The aftermarket leak fix additives contain a number of different plasticisers to restore oil
seals elasticity ans slighly swell them.
