mcerd1
| posted on 17/8/16 at 03:16 PM |
short tip spark plugs - whats the catch ?
in the ongoing build of my pinto I've found one more little snag - the fairly common issue of clearance for the spark plug tips....
I can just mark the standard ones and make sure they all line up the right way round - but are short tip ones a better option ?
also I was going to use the resistor version of the standard ones [NGK APR6FS] to work with the megajolt
snapper
| posted on 17/8/16 at 03:39 PM |
I have used the indexing method, mark outer insulator where earth electrode elbow is etc.
And have a head with plug inserts for 10mm plugs which pulls the plugs up so electrode does not protrude below head face.
I eat to survive
I drink to forget
mcerd1
| posted on 18/8/16 at 12:30 PM |
I may well just got with indexing the standard ones as its easy and I'd only need a couple of spare plugs
but I'm interested in the 10mm plug inserts - were did you get them and what plugs are you using ?
snapper
| posted on 18/8/16 at 05:09 PM |
Came with the head but I think Vulcan do them
Plugs are NGK BP7ES from Burtons
They have a longer thread but the insert pulls them up then the angle and the smaller diameter takes the electrode up from head face
I eat to survive
I drink to forget
mcerd1
| posted on 18/8/16 at 06:39 PM |
so I guess something like a BPR6EIX or BPR7EIX should work with the adapter too then
