xico_ze54
| posted on 1/9/16 at 05:38 PM |
help needed - Ford 1.6 CVH conversion
hi all
I got a motor 1.6 CVH from a 1990 (arround) Ford Sierra. the engine is good but the injection sistem broke and is not work.
so is that any kind of simple solution to put that motor running? put some simple carburetor or so without the need of dealing with electronics?
did someone already did that kind of stuff and has knowledge to tell me?
thank you in advance.
regards
Amadeu
http://www.viseudesign.com/Sevenesque-36.htm
mark chandler
| posted on 1/9/16 at 06:24 PM |
Most escorts had carbs on CVH engines, have a scratch about at a breakers.
xico_ze54
| posted on 1/9/16 at 06:38 PM |
and it's only make the exchange? don't need to work with ECUs or something else in the electronics?
| posted on 1/9/16 at 06:46 PM |
However the ports are slightly different on the injection engines but this can be worked round.
The ignition system on the FWD Escort 3 CVH was also much simpler just an electronic dizzie and coil.
[Edited on 1/9/16 by britishtrident]
