Samuele
| posted on 23/9/16 at 10:23 AM |
Raceline sump
You tell me any of you who mounted a 2.0 zetec engine with the oil sump raceline of the Fury if the cup comes out of the chassis ?
I mean , what is the lowest point of the car , the chassis or the oil sump ?
Dusty
| posted on 23/9/16 at 09:06 PM |
Don't know the specifics for a Fury but one point about the raceline sump is it bolts up flush with a type 9 bellhousing including the two
lowest bolts and is flush horizontally with the bellhousing. i.e. it does not stick down any lower than the bottom of the bellhousing. I have one poor
picture from when I fitted it. You can just about see the bellhousing and a sliver of the sump visible below the rail.
[img]
  sump
[/img]
[Edited on 23/9/16 by Dusty]
Samuele
| posted on 23/9/16 at 09:17 PM |
ok, this is an information that can be enough.
thank you
