Author: Subject: ST 170
the_big_1
posted on 2/11/16 at 12:53 PM Reply With Quote
ST 170
Hi All,
Anyone fitted the ST170 2.0L Zetec? Any issues different than the normal Silver / Black top Zetecs?
Cheers!
loggyboy
posted on 2/11/16 at 12:59 PM Reply With Quote
Just the running of the VVC/VVti is the only issue im aware of.
Just needs the correct type of management.
[Edited on 2-11-16 by loggyboy]
Mistral Motorsport
posted on 2/11/16 at 02:11 PM Reply With Quote
Or lock it.
Ugg10
posted on 2/11/16 at 02:37 PM Reply With Quote
I think the exhaust ports are in a slightly different place (higher ?) someone will confirm this I am sure. It is slightly taller as well. Everything else is basically a blacktop zetec so mounts, bellhousing, water pump etc. are all the same.
VCT controllers are available as a stand alone item if you do not want to buy the more expensive ECU with control built in (see thread on here about "free" ecu offer, may be of interest) and there is an "how to OEM" thread on here that may also help get it running in stock mode.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
posted on 2/11/16 at 03:13 PM Reply With Quote
Exhaust ports are the same, its the inlet ports that are a bit higher, nearside engine mount is different and the vvt valve sticks up out the rocker cover...
