Author: Subject: FOR SALE: MNR GM3 - Chassis, engine and body project
MK9R
posted on 27/11/16 at 10:58 PM Reply With Quote
I have now stripped off everything i require for the new build so the remaining kit is for sale. The car was fully working and racing until i decided to build a new, car, to keep costs down i decided to strip off everything i could use from this car to put on the new one. Its basically a full chassis, with wishbones, Engine and drive train, steering rack, fuel tank, plus all the wiring and brake lines. There are loads of bits ive missed out as i cant quite remember what ive left on it.
Fully CDS round tube Chassis built by Marc at MNR
T45 Cage
Ali floor
Unique front engined chain driven drive line, allowing easy change of ratios
Brand new chains and sprockets fitted start of this season. Spare sprockets for ratio changes included
Custom Viscous LSD.
Electric reverse
Fully rose jointed Latest inboard rocker rear suspension setup
Full rose jointed Front inboard rocker suspension
rear ARBs
Quick rack
Ali fuel tank - baffled and foam filled
2009 ZX10r motorcycle engine, including billet sump, baffle plate and oil cooler take off, plus another spare engine (big end knocking)
Tony Law Exhaust system (2 setups for different exhaust exits)
Custom airbox
Power commander
Full wiring loom, inc most switch gear etc
Battery
front floor and cooling ducts cooling ducts
1 piece upper body work and new style sills
The price, well with all of the above id like £4000, which would be a massive saving on building up to this stage from new. The car has only competed for 2 seasons and the chassis has never sustained any damage. The bodywork will need a respray. If you require any new parts or body panels they are all readily available from MNR.
This can be road registered if required, kept as a race car, trackday car or would make a brilliant sprint car.
Id sell the engine package seperaterly if wanted, but ideally id like to clear out everything together.
Photos to follow
[Edited on 27/11/16 by MK9R]
[Edited on 28/11/16 by MK9R]
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
MK9R
posted on 28/11/16 at 01:05 AM Reply With Quote
Gallery of pics as car is now. Note wishbones are all included but not fitted to car in photos
https://goo.gl/photos/ei9u8ZER741Z8pKU8
Cheers Austen
RGB car number 9
www.trackace.co.uk
