Author: Subject: 2.0 DTi Vauxhall engine bhp ?
locoboy
posted on 3/1/05 at 07:37 PM Reply With Quote
Anyone any ideas on the BHP figures on the 2.0 DTi Vauxhall engines as fitted to 2000 (W) reg Vectras?
Locoboy
Trev Borg
posted on 3/1/05 at 07:46 PM Reply With Quote
Type: S-4
SOHC
16 valves total
4 valves per cylinder
Bore x stroke: 84.00mm × 90.00mm
Bore / stroke ratio: 0.93
Displacement: 1995 cc 121.74 cu in
Compression: 18.50:1
Aspiration: Turbo D.
Catalytic Converter: Y
Max. output: 100.4 PS (99.0 bhp) (73.8 kW)@4000 rpm
Max. torque: 230.0 Nm (170 lbft) (23.5 kgm)@1500 rpm
Coolant: Water
Specific output: 49.6 bhp/litre
Specific torque: 115.29 Nm/litre
Performance
0-100km/h: 13 s
Top speed: 192 km/h
CO2 emissions: 159 g/km
Power to weight: 65.87 bhp/ton
Chasis
Engine location: Front
Engine alignment: Transverse
Steering: rack & pinion PAS
Turns lock-to-lock: 3.200
Turning circle: 10.90 m
Wheels F/R: 6.5J x 15/6.5J x 15
Tyres front: 195/65 R 15H
Tyres rear: 195/65 R 15H
Brakes: VeDi/Di-S-ABS
Brake diametre: 285/278 mm
Transmission: 5M
Drive: FWD
Top gear ratio: 0.69
Final drive ratio: 3.74
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
posted on 3/1/05 at 07:52 PM Reply With Quote
Trev - that should cover it then
posted on 3/1/05 at 07:53 PM Reply With Quote
99.2 then?
locoboy
posted on 3/1/05 at 09:01 PM Reply With Quote
Trev where is that from - i assume you are not a Vauxhall specialist - it would be interesting to compare that to a 306 HDI 2000 (W) reg.
Locoboy
ned
posted on 3/1/05 at 11:00 PM Reply With Quote
hdi comes in 90 and 110bhp varieties iirc, not sure on torque or other details though I'm afraid. Then there's the vw pd series units, 90,110,115,130,150bhp iirc as well..
Ned.
beware, I've got yellow skin
Mark Allanson
posted on 3/1/05 at 11:09 PM Reply With Quote
You can wind up the new VW/Audi 2.0 TDI's to over 200BHP with a little chippery
Trev Borg
posted on 4/1/05 at 07:25 AM Reply With Quote
globalcar
i think its usa spec's tho'
skippad
posted on 4/1/05 at 10:33 PM Reply With Quote
Trev
Thats hell of a transplant job in the gemini!.
Whats the spec on the alfa engine and what gearbox, axle and hubs/brakes are you using?
Cheers Skippa D
Trev Borg
posted on 5/1/05 at 12:20 PM Reply With Quote
The transplant was so easy, took me less than a day to do.
step 1 removed engine from donor.
Step 2 lifted the bonnet on new car.
Step 3 balanced alfa engine in chassis
step 4 close bonnet and drink tea
ta da all done (apart from it not working)
We are still doing some of the work to get it bolted up.
The engine is the 3.0 12v V6 from the alfa 164. Ally block, heads. sump.
Manufacturer: Alfa Romeo
Type: V-6
in 60° vee
SOHC
12 valves total
2 valves per cylinder
Main bearings: 4
Bore x stroke: 93.00mm × 72.60mm
Bore / stroke ratio: 1.28
Displacement: 2959 cc 180.56 cu in
Compression: 10.00:1
Fuel system: Bo Mot fuel inj.
Aspiration: Normal
Max. output: 202.8 PS (200.0 bhp) (149.1 kW)@5800 rpm
Max. torque: 264.0 Nm (195 lbft) (26.9 kgm)@4400 rpm
Coolant: Water
Specific output: 67.6 bhp/litre
Specific torque: 89.22 Nm/litre
We have made a belhousing to fit the type 9 box but are just refining it. If there is any interest in using these engines we will farbricate some in alloy.
Going to use the standard injection system (the engine loom is separate from the rest in the alfa)
Everything else on the car is cortina I think.
We keep hitting a few minor problems but think we can overcome most of them. My friend owelly is the brains and manufacturer behind all of this.
It should turn out to be a nice looking nice sounding car if we get it finished
[Edited on 5/1/2005 by Trev Borg]
Project7
posted on 6/1/05 at 10:39 AM Reply With Quote
this place is good for production car stats
www.carstats.co.uk
