Author: Subject: propshaft
Nightkid
posted on 5/1/05 at 12:04 AM Reply With Quote
propshaft
Hi all
I been reading the Haynes restoration manual on escort and cortina and it mention that the 1100cc model have a one piece propshaft and the 1300cc have a two piece propshaft. Is the dimension different that I need to be aware of?
paulf
posted on 5/1/05 at 10:07 PM Reply With Quote
One thing to bear in mind is that the 1100 prop will have a smaller flange on the axle UJ.
I had the opposite situation and had to change the drive flange on my 1100 diff to suit the propshaft which had a capri or sierra size flange .
Paul.
posted on 6/1/05 at 09:39 AM Reply With Quote
Paul.
Propshaft Flange size has no connection engine size, it changed circa 1975 --- typical Ford no exact change over date but generally Mk2 Escorts use same flange as the Mk3+ Cortina, Sierra Mk2+ Capri.
paulf
posted on 6/1/05 at 10:10 PM Reply With Quote
My axle came from a 1978 mk2 1100 and had the smaller flange, unfortunately I didnt get the matching propshaft at the time .
Paul
