Author: Subject: Fuel Tank Breather
Barksavon
posted on 13/3/17 at 10:27 PM Reply With Quote
Fuel Tank Breather
Has anyone used one of these
Aero Tech Tank Vent Valve -6 Vent Inline To Suit -6 Hose 3/8" hose barb
as a fuel tank breather. I've read previous threads where it has been suggested they only work to relieve vacuum in the tank, however i e mailed a question to Demon Tweeks who replied that this item relieves pressure build up and vacuum.....?
ian
ste
posted on 13/3/17 at 11:03 PM Reply With Quote
I used a roll over vent as I believe to pass iva it needs to vent freely
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR0.TRC0.H0.Xfuel+tank+roll+over+vent.TRS0&_nkw=fuel+tank+roll+over+ven t&_sacat=0
ste
posted on 13/3/17 at 11:06 PM Reply With Quote
Thi sis the one I have, and have a barbed connector on it to a hose to vent up higher
AN -6 6AN AN6 Roll Over Vent Valve Tank Mounted Black
[Edited on 13/3/17 by ste]
tims31
posted on 14/3/17 at 04:07 PM Reply With Quote
I've just been look at the roll over/vent valve for mine but I need an inline one that pushes onto a hose, what have others used or can suggest as options please.
Build: http://www.martinsfurybuild.co.uk/
big-vee-twin
posted on 14/3/17 at 08:22 PM Reply With Quote
I used this link passed IVA no probs.
http://www.triangleltd.com
tims31
posted on 16/3/17 at 01:14 PM Reply With Quote
I didn't think this was a roll over valve just a vent although I see someone has asked the question at Demon tweeks
Barksavon
posted on 17/3/17 at 01:41 PM Reply With Quote
I asked Demon Tweeks whether this handled vacuum and pressure and they replied yes. Ive bought one and can't really see how it can deal with both situations in a single installation as it is basically an inline one way valve, depending on which way its put inline it will relieve either a build up of pressure or a vacuum but not both.....or am i being a bit thick.
Ive only got a small fuel tank (17 litres) and its got a breather pipe coming out the top which i dont want to leave uncapped. Unsure which way to fit the valve now, either to relieve pressure or vacuum.....?
phelpsa
posted on 17/3/17 at 01:54 PM Reply With Quote
Its a rollover valve. When upright it flows freely in both directions, when inverted it is shut. It must be mounted vertically.
Edit: Ignore me, there is nothing in the lunk to confirm my assumption. Although it could be true.
[Edited on 17-3-17 by phelpsa]
tims31
posted on 17/3/17 at 02:04 PM Reply With Quote
I emailed ATL about this valve and they stated that it is NOT a roll over valve only a breather and so should fail IVA really. Looks like I will have to go for this one for 8mm inline hose https://www.merlinmotorsport.co.uk/p/roll-over-v alve-in-line-with-5-16-8mm-push-on-tails-m-trl88
[Edited on 17/3/17 by tims31]
