bob
posted on 17/10/02 at 06:53 PM |
VENT FOR FUEL TANK
Cant have a vent in fuel cap,so will have to make one in filler tube.
I've got an idea but thought it best to get a view from other builders as well.
Any clues lads ?
locodude
posted on 17/10/02 at 07:17 PM |
Bob
The tank itself will take a 1/4 bsp thread if theres not enough room to get one on the Pad with the outlet connector. Get a 1/4 bsp to 8 or 10mm
copper compression fitting put a small piece of tubing on it and then run some bagging from that. Failing that use the same connector but tap the hole
into the filler neck, it should be plenty thick enough. I put a large pad on now, big enough for a sender unit and vent!
[Edited on 17/10/02 by locodude]
bob
posted on 17/10/02 at 09:21 PM |
Cheers chris
My thoughts were to tap it,just needed reasurance from my tank maker.
One of many top quality black plastic parts i have purchased.
eeeerr will that do!!!!
locodude
posted on 17/10/02 at 11:01 PM |
That'll do nicely!
