Author: Subject: Exhaust Mount Cotton Reels
AntonUK
posted on 21/5/17 at 09:04 PM Reply With Quote
My exhaust is mounted at the rear by a single rubber cotton reel style mount.
Does anyone have a recommendation for a decent quality supplier? My rubber one fitted last year perished and cracked. This year I fitted a supposedly better poly version and this thing just melted and broke in two.
Build Photos Here
hearbear
posted on 21/5/17 at 10:45 PM Reply With Quote
Our company used 40mm bobbins for safety barriers on the rear of bin lorries which were forever being reversed into immovable objects and it took a lot to burst them. Might still have one in garage could post if you feel it my work for you. Let me know and will have a look and sort it for you.
Cheers George
3.9Ltr SSC Stylus should be fun
ste
posted on 21/5/17 at 11:09 PM Reply With Quote
I used these
4 x M8 20x30MM Anti Vibration Rubber Bobbin Mounts Male Female Boat Car Damper
and made this
WallerZero
posted on 22/5/17 at 08:59 AM Reply With Quote
I've used these guys for a number of things both personal and business. Loads of options and more importantly, everything I've ordered has arrived within 24-48 hours
http://www.wdsltd.co.uk/categories/75/anti-vibration-mounts/
All sorts of random things on there and many fancy bolt side project ideas for the kit are growing lol
http://zachsgbszero.blogspot.co.uk/
motivforz
posted on 22/5/17 at 11:30 AM Reply With Quote
My piece of advice for these is make sure you get ones with spanner flats built into them - that way when you tighten up against them you're not shearing the rubber and can stop it from twisting when it's installed. A company producing these is less likely to use cheap rubber (perhaps).
For example, these ones:
Set of 4 Anti Vibration Mount / Rubber Mounts / Hexagon Male Male M8x16mm
dave r
posted on 22/5/17 at 06:54 PM Reply With Quote
also if you can make the bracket so it is compressing it rather than hanging from it...
mine last much longer that way
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
