dblissett
posted on 8/1/05 at 06:10 PM |
ignition maps
has anyone got a ignition map for a megajolt running a 2ltr pinto with tps
i can sort out the 2d map side but i dont know what sort of advance to program in for the part throttle advance
how much does the standard vacuum advance, advance the timing by
i have read on dave andrews site this could be as much as 15 degrees
cheers dave
cidersurfer
posted on 9/1/05 at 08:56 PM |
Might be worth looking here...
http://www.cate1.co.uk/megajolt/mapping.php
HTH
Chris
shimming solid lifters is a job for a friend...
dblissett
posted on 10/1/05 at 10:13 AM |
map
thanks
but that curve is only 2d and i am looking for one with tps advance to make it 3d
cheers dave
PioneerX
posted on 10/1/05 at 01:34 PM |
I dont have Zetec ones, but Matt (see above) might be able to help you there. But I do have Vauxhall ones might give you starting point, there are at
weblink
dblissett
posted on 10/1/05 at 01:43 PM |
map
thanks pioneerX i understand the rpm advance but is the 1 to 14 scale vacuum advance and are you running 50 deg total advance thanks dave
[Edited on 10/1/05 by dblissett]
PioneerX
posted on 10/1/05 at 01:58 PM |
dblissett,
The 1-145 are known as BIN's and simply represent a value. You are right to assume the BIN's on the main files I have on the site are
Vacumn, but this is a linuar scale in the rough map I'm using.
I have replaced the BIN values with vacumn values of 20kpa to 110kpa. For TPS you simply need to replace these with a range from your minium to maxium
values. Remember the MegaJolt software will still show your values in kpa. If you use the realtime display while the engine is off to see what you
thottle closed & fully open values are you can work out a suitable scale.
Also remember the spreadsheet witht he Vauxhall maps in are too big for MegaJolt as that is only 10x10. There is a converter spreadsheet included.
BTW: After the convertion has done the interpolation (spelling???) my maps max advance is 38Deg + 10Deg applied by the EDIS module = 48Deg.
[Edited on 10/1/05 by PioneerX]
chriscook
posted on 10/1/05 at 07:12 PM |
Do you know what state of tune the 20XE map in your files area is for?
thanks,
Chris
dblissett
posted on 10/1/05 at 08:41 PM |
total advance
hello pioneerx the total advance all in for a tuned pinto is normaly 36 to 38 degrees
and i have read from dave andrews site that pent type heads ( like your vauxhall )
need less or have i got it wrong as usual
daves site is http//hometown.aol.com/dvandrews/timing.htm
cheers dave
PioneerX
posted on 11/1/05 at 10:54 AM |
I think your right, after I posted I thought long and hard about whether or not 10 degrees had to be added for the EDIS module and decided that I
someone would know either way and correct me if I'm wrong.
I stand corrected
I dont know the state of tune off the top of my head as the map was not produced by me, but I will look it up and get back to you.
dblissett
posted on 12/1/05 at 06:24 PM |
vac advance
hello pioneerx i am not to sure either
for example a
when my pinto is running at 3600rpm with the throttle wide open the advance will be 38 degrees but when i close the throttle should the vac advance
it a further 15 degrees ie a total of 53 degrees
or should the total advance never exceed 38 degrees
so example b
when running at 2000rpm advance should be about 20 degrees with a wide open throtle and 35 degrees( 20 degrees pluss 15 vac advance) with it closed
i can the plot the rest of the curve
i know this wont be spot on but it should be close enough to get it on a rolling road
am i right or just going mad slowly
cheers dave
mattdearden
posted on 13/1/05 at 09:41 AM |
Pinto Maps
Dave - I've now updated my website with a 3D Pinto map, suitable for tuned Pinto's reving to 6k. If yours goes more than this then let me
know and I'll upload a modified map which goes up to 8k.
Do note, you'll probably have to change the values on the TPS to suit your setup.
Matt Dearden
(2lt Pinto Cat)
http://www.swtoc.co.uk
dblissett
posted on 13/1/05 at 07:03 PM |
maps
cheers matt could you email me the 8k map as i plan to rev it to 7k
top work
my email is david.blissett@ntlworld.com
thanks dave
[Edited on 13/1/05 by dblissett]
mattdearden
posted on 14/1/05 at 01:55 PM |
done
Hi dave,
I've uploaded the 8k map to my site here:
Let me know how it goes
cheers
Matt Dearden
(2lt Pinto Cat)
Rob Allison
posted on 15/1/05 at 03:19 AM |
Matt interesting stuff on your web site. I'm just about to order a MSnS from Bill. Getting a built unit though. I was also after some baseline
maps to start working with.
Only thing is i'm running a 2.0 pinto with a turbo. Not sure when the ignition needs to be retarded from, listen for the rattle i guess
JJM
posted on 15/1/05 at 02:38 PM |
Does anyone have a map for an xe on 40's done yet please? Standard cams.
Thanks, John.
