ttalps2000
posted on 25/10/17 at 07:27 AM |
Zetec Oil Filter Part No.
Does anyone know the oil filter number for a zetec 1800 silver top? It is the filter that is attached to the oil pump and comes out by the crank.
Forgot to get the numbers off it last night!
jossey
posted on 25/10/17 at 08:45 AM |
The tall one or short?
[Edited on 25/10/17 by jossey]
David Johnson
jossey
posted on 25/10/17 at 08:54 AM |
Tall is l10169ps
Part number 501590018
Short one Is l10174ps
Part number 501590068
Got mine from euro car parts for about £4
Hope that helps
Both are Crosland part numbers.
David Johnson
ttalps2000
posted on 25/10/17 at 08:55 AM |
It has a long one on there at the moment, but tempted with a short version to give me a little more space!
matt5964
posted on 25/10/17 at 09:31 AM |
Short one mahle oc606 is what I use only £2.00 from our local motorfactors
Luego velocity XT 2.0ltr 221.3bhp 178.9lbft
jossey
posted on 25/10/17 at 09:47 AM |
I've used short for ages now
David Johnson
kingster996
posted on 25/10/17 at 09:53 AM |
Westfield supply engines with a WIX WL7064. The WIX box states the
following equivalents:
MANN W9101
KNECHT OC11
FRAM PH2874
PURFLUX LS506
FIAAM FT4763
FILTRON OP518
taller one:
FRAM PH966B
Crosland 573
Mann W712
Six WL7098
I used to be indecisive, but now I'm not so sure
big_wasa
posted on 25/10/17 at 11:04 AM |
I use these as well.
DJT
posted on 27/10/17 at 11:01 AM |
Short one: Mann W77. Has the correct imperial, not metric, thread. Think it might cross reference to other models posted here.
http://tigeravonbuilddiary.blogspot.com/
SteveRST
posted on 2/2/18 at 02:25 PM |
If you need a REALLY short filter (as I did) then the Mann W85 is 49mm high (10mm shorter than the Mann W77) BUT it does not have the Zetec 3/4
UNF thread, but an M20 thread so you'd need a 3/4 > M20 converter spigot like this:
https://www.speedflowshop.co.uk/m20-to-34-unf-oil-filter-fixing-spigot-570-m20-34-3450-p.asp
I had to use it as couldn't find filter that short in 3/4 (though I'm sure there is one out there).
