Author: Subject: which engine???
paul_mcq
posted on 13/1/05 at 04:06 PM Reply With Quote
which engine???
i'n getting my car hopyfully in week and need to no this, out of these two which is the best? the 2 litre zetec or the 1.8 k series? i need to no which is the best allround on reilablity tuning etc. and would both of them work well on webers? plz get back to me. cheers
shortie
posted on 13/1/05 at 04:17 PM Reply With Quote
From a reliability perspective I guess the 2 litre Zetec would be better given the 1.8k series record with Head Gasket failure.
Tuning, I guess they are both pretty tunable but depends how much you want to spend!
Not sure about the webber question.
Rich.
posted on 13/1/05 at 04:53 PM Reply With Quote
No third option - proposterous!!!
BEC anyday!
zetec
posted on 13/1/05 at 06:16 PM Reply With Quote
Go for the zetec, cheaper and more reliable, just as easy to tune. Lot more info on here how to fit it and get running.
Most zetecs running on webers in converted and kit cars. Suspects K series also OK. Go for injection if you can, worth the effort and just as easy once you get started.
[Edited on 13/1/05 by zetec]
" I only registered to look at the pictures, now I'm stuck with this username for the rest of my life!"
smart51
posted on 13/1/05 at 07:45 PM Reply With Quote
2.0i Zetec = 145 BHP
1.8i Kseries = 118 BHP
2.0i Zetec = 115 kg
1.8i Kseries = 99 kg
I believe that it is only the later 1.8 Ks, with head sealant rather than a gasket, that are prone to leaks.
you pays your money...
BMF
posted on 14/1/05 at 03:54 PM Reply With Quote
My 2p!
Vauxhall XE any day! 165BHP min with carbs, and endless possibilities!
posted on 14/1/05 at 05:34 PM Reply With Quote
The 1.6 K series is a better bet than 1.8 .
stressy
posted on 14/1/05 at 05:49 PM Reply With Quote
1.6k series EU2 engine with fuel injection is my choice. Keep the standard ecu, injection system etc and its cheap and reliable out the box. Get a low milage one and thereusually pretty good.
Save you weber money (and what you would have spent on a zetec ecu) and go for throttle bodies and cam latter and youve got a real spagly little engine.
K series is actually a very light installation, the real problem is the height of the engine and the ratios in the type 9 box.
WHO DARES SPINS
posted on 14/1/05 at 06:45 PM Reply With Quote
And just changing the throttlebody for alloy one with the bigger hole can make a big difference.
wilkingj
posted on 14/1/05 at 07:34 PM Reply With Quote
I heard an interesting snippet on the "K" seeries engine head gasket saga.
Evidently there is a chap / company making Competition gaskets that have a complete sandwich of gasket goo in them, and they do not leak..
Cant remember the gasket company... began with a "P" ?? Padney? or simmilar
Best Regards
Geoff
http://www.v8viento.co.uk
