brumster
posted on 7/3/18 at 10:35 AM |
7.25" clutch, Caterham Duratec flywheel+clutch
Bit of a clearout... found some bits that can go... all plus postage as items are obviously heavy, or collection from Birmingham NEC area.
190mm (7.25" clutch cover, standard, <500 miles of use. Typical fit for Ford Crossflow (came off a K-Series running on a type 9). £35
Caterham/Duratec lightweight flywheel, 215mm (8.5" AP racing clutch 1"/23T spline. Flywheel and cover have signs of use, heat spots and
minor surface wear, nothing that you wouldn't expect but I'm not pretending they're brand new and in perfect condition . Friction
plate is brand new, CP5352-14 part number, specs are 7.11mm thickness brand new so you can see it is fine - they're £150 new alone.
£100 flywheel, £100 friction plate, £50 cover.
brumster
posted on 10/3/18 at 08:47 AM |
Duratec 8.5" clutch (friction plate and cover) now SOLD.
Duratec lightweight Caterham flywheel and 7.25" clutch still available
brumster
posted on 20/7/18 at 07:25 AM |
Flywheel gone; 7.25" clutch still available, open to sensible offers
GavMax
posted on 20/7/18 at 12:58 PM |
Hi
Could I see a photo or two of the clutch please?
The original photos aren’t showing on my machine.
brumster
posted on 20/7/18 at 02:46 PM |
Hmmm not sure what's going on there... try again :
[Edited on 20/7/18 by brumster]
GavMax
posted on 20/7/18 at 04:47 PM |
Hmm
Still not working
GavMax
posted on 20/7/18 at 05:57 PM |
It is now
