motojohn
posted on 20/7/18 at 06:22 PM |
Zetech 1800 to type 9 gearbox
i know may have been asked before but how hard is it to fit a zetech engine to a type 9 gearbox i only ask as im thinking of junking my very old
motor for something with fuel injection .
thanks for any information
Schrodinger
posted on 20/7/18 at 07:17 PM |
It's fairly straight forward, they bolt together on most of the holes but you will need to get the correct starter, clutch and thrust bearing.
Keith
Aviemore
Ugg10
posted on 20/7/18 at 07:22 PM |
And need to put a spigot bear in in the zetec crank shaft end, stock ford Sierra part.
I posted some info on this thread, I think it tells you what clutch, starter and spigot bearing to use.
https://www.locostbuilders.co.uk/viewthread.php?tid=212368
[Edited on 20/7/18 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
tims31
posted on 21/7/18 at 05:48 AM |
Yep, as said fairly easy to do.
I've posted details on my build blog for a 2.0ltr zetec which is much the same.
[url=http://www.martinsfurybuild.co.uk/engine.html#ClutchGearboxBellhousing]http://www.martinsfurybuild.co.uk/engine.html#ClutchGearboxBellhousing[/ur
l]
[Edited on 21/7/18 by tims31]
Build: http://www.martinsfurybuild.co.uk/
big_wasa
posted on 21/7/18 at 11:44 AM |
You can also get a pinto style Zetec flywheel that will take your pinto clutch and starter ect. Just add a spigot bearing.
chris
posted on 21/7/18 at 03:31 PM |
The 1.8 flywheel and 2ltr pinto clutch fit together with some minor fettling and use pinto thrust bearing so just starter motor Ls707 r I got mine on
ebay £80
chris
posted on 21/7/18 at 03:38 PM |
Oops
[Edited on 21/7/18 by chris]
big_wasa
posted on 21/7/18 at 04:53 PM |
As you can see there are 101 ways to get the job done.
motojohn
posted on 22/7/18 at 07:01 AM |
thanks food for thought, im still not sure what engine i will use weather to go for something modern and fuel injected or go old school with a pinto
and twin webbers
