Author: Subject: Which bike throttle bodies for an xe?
Northy
posted on 18/1/05 at 09:21 PM Reply With Quote
Hi guys,
What different types of bike throttle bodies have people heard of been used on an xe (Vauxhall 2L 16v Red Top)?
I know there's someone on here (Cidersurfer) using GSXR 750's, and I James thought Blackbird ones could be used. Does anyone know for sure if Blackbird ones are a good idea?
I could do with some recommendations? There's a big autojumble soon and I'd like to go and look for some.
I asked a guy at work (who's big into bikes) and he said Blackbird stuff would be much cheaper than GSXR stuff.
Graham
Trev Borg
posted on 18/1/05 at 09:31 PM Reply With Quote
Have you been to Boggy's.
He's near you isn't he ?
I think he does a lot of em.
Before you judge a man, walk a mile in his shoes.
By that time, who cares.
You're a mile away, and you've got his shoes
skippad
posted on 18/1/05 at 09:33 PM Reply With Quote
who's Boggy?
Wheres he at?
Northy
posted on 18/1/05 at 09:43 PM Reply With Quote
Yeah,
Boggy set up my Webbers. I thought he was only into bike carbs?
Skippad, Boggy is a local legend. He a local rolling road / setting up carbs / old school kind of guy. He's at East Lutton near Malton. They've just started fitting bike carbs to car engines with alot of success.
[Edited on 18/1/05 by Northy]
Graham
skippad
posted on 18/1/05 at 09:52 PM Reply With Quote
He sounds interesting!!!
Is in yellow pages?
Northy
posted on 18/1/05 at 09:54 PM Reply With Quote
Probably. Bogg Brothers, East Lutton. Try that. He's deffo a character!
Graham
skippad
posted on 18/1/05 at 09:58 PM Reply With Quote
Ta!
Northy
posted on 18/1/05 at 10:02 PM Reply With Quote
Now what about my throttle bodies!
Graham
big_wasa
posted on 18/1/05 at 10:10 PM Reply With Quote
throttle badies
Bogg Brothers
The Garage
East Lutton
Malton
YO178TG
01944 738234
Fast ford feb issu has done 4 page spread on these guys very good read, worth the£3.70 just for that..
They recomend any of the 1000 super bikes as donors as they have bodies of over 38mm with the Hayabusa toping out at a whopping 43mm.Look on Ebay a set of these will set you back £100-£175 carbs are less £20-£100.
The carbs on most sports 600's are about 36mm and are very cheap hmm just need some thing to run the ignition? any one have any ideas if quad 36mm carbs will be enough on a 1800 zetec?
cidersurfer
posted on 18/1/05 at 11:35 PM Reply With Quote
Yep, I'm attempting to use GSXR 750 TBS. A quick tip though, Year 2001 up had injectors with higher flow rate of 270ccm @ 3 bar, I think Blackbird ones have similar (or more) output. Also, most bike TBs will have smaller centres (distance from body to body) than most car engine inlets so look for ones that are individual bodies that come apart so you can increase the spacing to match your manifold. Some come in pairs too.
As an indicator I paid £80 from a breakers for bodies, injectors, tps, linkage, short loom, MAP pipes and fuel rail delivered to my door.
HTH
shimming solid lifters is a job for a friend...
cidersurfer
posted on 18/1/05 at 11:57 PM Reply With Quote
Just for info
GSXR 600's are;
Inlet 41mm
Outlet 38mm
Equivalent to Jenvey tapered 48 (apparently)
GSXR 750's are;
Inlet 50mm
Outlet 42mm
Equivalent to Jenvey tapered 45 (apparently)
If you want to change injectors, Denso injectors off say, a Supra fit most of the bike bodies.
Northy
posted on 28/1/05 at 09:43 PM Reply With Quote
What year GSXR 750 throttle bodies should I be looking for? There are loads!
Graham
cidersurfer
posted on 28/1/05 at 10:05 PM Reply With Quote
I've got 2001 ones, single bodies and the higher flow rate injectors. Not sure about others though, sorry!
billy
posted on 28/1/05 at 11:19 PM Reply With Quote
dam i picked up some gsxr 750 carbs the early ones
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
ned
posted on 29/1/05 at 03:48 PM Reply With Quote
i picked up some qed direct to head throttle bodies, but i suspect they're a little more expensive than bike ones
Ned.
beware, I've got yellow skin
Northy
posted on 29/1/05 at 04:00 PM Reply With Quote
Ned,
Are you at work!
Graham
ned
posted on 29/1/05 at 07:30 PM Reply With Quote
no, struggling on 32mb ram and dialup at home..
Ned
Northy
posted on 29/1/05 at 07:35 PM Reply With Quote
Graham
Northy
posted on 29/1/05 at 09:59 PM Reply With Quote
Just found this on the Racecar forum:
You may want to wait a few months, some of the 2005 bikes are now going to be fitted with oval bodies which apparently (or so Kawasaki claim for their new 600), are 20% more efficient than a round body. Won't be long before a few of them are thrown down the road. Since the bodies won't fit anything else, they should be relatively cheap.
Graham
