Author: Subject: Hydraulic clutch for type9/zetec help
Daz1234
posted on 6/9/18 at 10:43 PM Reply With Quote
Hi all
I might be doing the above conversion.
I know there are several kits out there but want it make sure I get the right one.
Anyone done this conversion and if so what did you buy and from where?
Darren
ttalps2000
posted on 7/9/18 at 12:44 PM Reply With Quote
I used the kit from Burton Power. They do 2 types. You will need to get the relavant spacer too and machine this accordingly. Best advise is to dry fit it all, do all your measurements, fit box to engine and check all etc.
Quite easy to do
Tonesta
posted on 7/9/18 at 04:14 PM Reply With Quote
Hi I bought one from MLR and Bought a spacer and ss braided hoses from Burton’s .
I did take pictures of it all when I was fitting it, I can send them through to you if it helps ?
sandhu
posted on 8/9/18 at 01:53 AM Reply With Quote
Turbo sports do I that does not need cutting
