RICK1
posted on 19/1/05 at 10:26 PM |
MT75 TO 2.0ZETEC
THIS MUST BE A BORING QUESTION 2 ALL YOU EXPIERENCED BUILDERS. BUT WHAT FLYWHEEL+CLUTCH AND RELEASE BEARING 2 USE + DO I AFTER MODIFY THE CLUTCH ARM.
AND WHAT STARTER MOTOR 2 USE.?
garage19
posted on 19/1/05 at 11:54 PM |
The only thing you need is a Westfield extended clutch release bearing (50 quid).
Everthing else is stock 2ltr clutch components.
Doug.
Mix
posted on 20/1/05 at 09:22 AM |
I'm using a flywheel, clutch pressure and friction plates from 1.8 Mondeo, starter from 2.0 DOHC (8 valve) and am modifying the original MT75
release bearing. You will also need a spigot bearing.
Mick
James
posted on 20/1/05 at 12:48 PM |
RICK,
DON'T SHOUT!!!
It's bloody annoying!
James
shaywez
posted on 20/1/05 at 05:18 PM |
zetec/mt75
Hi, i have used 2.0ltr zetec with origional flywheel, new clutch and a modified Westfield release bearing Part No 324009. You will also need a spigot
bearing to go into the end of your crankshaft to support the gearbox primary shaft (input shaft part No 324002, both those parts came to £63.20 inc
vat and postage
