Author: Subject: Heat sleeve
Shooter63
posted on 25/11/18 at 06:21 PM Reply With Quote
Heat sleeve
As I've top mounted my turbo the oil drain is running quite close to the manifold, I'm trying to find some heat sleeve to cover the hose with, so far the stuff I've found seems quite spend, I've thought about using exhaust wrap, what do you guys think
Shooter
obfripper
posted on 25/11/18 at 07:59 PM Reply With Quote
This is like oe fit sleeving, there's cheaper stuff from china if you can bear the wait.
https://www.ebay.co.uk/itm/Silicone-Fibreglass-Fire-Sleeving-Protective-Heat-Shield-Sleeve-Black-0-5m/192217278688
Dave
Shooter63
posted on 26/11/18 at 06:30 AM Reply With Quote
Dave
Thanks Dave, it should do the job
jester
Contributor
Posts 188
Registered 21/5/17
Member Is Offline
Photo Archive Go!
Building: brought Jester.building a Jester own a Striker
posted on 27/11/18 at 01:47 PM Reply With Quote
Or here fast shipping
https://www.merlinmotorsport.co.uk/s/heat-insulation/thermal-heat-sleeve-insulation
