Author: Subject: Banging noise when depressing clutch, causes drag
Paul TVR
posted on 2/3/19 at 08:36 PM Reply With Quote
I have a C20XE engine with type 9 gearbox using a Caterham bell housing, its a cable operated with what i assume is at standard release bearing and arm.
When I depress the clutch I get a banging noise, its not not engine speed related, when the bang happens the clutch drags a little.
I'm assuming the clutch arm is catching something, but can't see much through the bell housing hole, any ideas?
AdamR20
posted on 2/3/19 at 09:56 PM Reply With Quote
Cable end nipple sliding / moving in the release arm?
avagolen
posted on 3/3/19 at 05:53 PM Reply With Quote
It could be that the clutch release arm is going too far. Mine did that until I changed the pedal ratio.
If you have a pedal stop, adjust it out to reduce pedal travel. If not it might be worth installing one or changing the pedal ratio.
CosKev3
posted on 3/3/19 at 07:02 PM Reply With Quote
As above,possibly over throwing the clutch.
So the spring fingers are touching something on the clutch plate as it's spinning
Paul TVR
posted on 3/3/19 at 08:23 PM Reply With Quote
Don't think it's down to the clutch adjustment, today I tried backing off the adjuster so could only just get gears, but still it happens. Seemed to happen worse when hot, but since found a bad oil leak from the rear engine seal, seems engine will be coming back out.
