pmc_3
posted on 23/1/05 at 02:21 PM |
Pinto wont start
I'm thoroughly hacked off atm. Every time I fix something I find another problem! Car was running fine yesterday, infact I went for a 40mile
drive with out the roof on which was cold Today I came out and it wouldnt start. I could smell the fuel so I reckon thats ok. The first thing I
tried was putting a plug and lead direct out the coil and earthing that on the block, no spark. The wire going from the - on the coil looks ropey
where it joins the distributer, would that cause the problem? condeser? I dont think the points were sparking either, but I couldnt see very well as I
was trying to turn the key whilst lean over the engine bay.
I'm trying to get the car ready for donington end of next month and i've got loads to do. Fit the front disc setup, change the pedal box,
change the sump, change the alternator, get an engine mount made up, do a service, get the exhaust manifold welded up, fit fuse box and get some new
tyres Gonna be busy!
[Edited on 23/1/05 by pmc_3]
bob
posted on 23/1/05 at 06:17 PM |
Switching wire come off on starter motor ?
Worth a look,happened to me before on my old cortina.
pmc_3
posted on 23/1/05 at 08:00 PM |
Its turning over ok. I'm just not getting a spark
tractorboy
posted on 23/1/05 at 08:08 PM |
is the distributer loose ie it has turned slightly putting the timing out? or has an earth cable become disconnected either from the battery to the
chassis or from the engine to the chassis?
Stu16v
posted on 23/1/05 at 08:16 PM |
Fit the front disc setup, change the pedal box, change the sump, change the alternator, get an engine mount made up, do a service, get the exhaust
manifold welded up, fit fuse box and get some new tyres
Thats next Saturday sorted, what you doing Sunday?
If you dont have any spark, start by going back to the basics. Have you got 12v (or 9v if ballast ignition) at the +side of the coil? If not, supply
problem.
If OK, remove the wire that goes to the dizzy off the coil. Get a piece of wire, attach to an earth, and with the ign on, 'flash' the wire
over the -coil terminal. This should generate a spark at the coil lead. If not, buggered coil.
If OK, take the dizzy cap off, and check the points gap. Should be 15thou for Lucas/Bosch dizzys, 25thou for Motorcraft IIRC. While you are doing
this, check that the points faces are not too pitted/worn. Serious burning indicates that the condenser is knackered. In fact, for the price of them,
it might be an idea just to replace them anyway TBH...
If it hasn't got sparks by now, the only thing left is the wire between the dizzy and the coil...
HTH Stu.
pmc_3
posted on 23/1/05 at 08:33 PM |
Thanks Stu. I wondered if it was the amount of power getting to the coil. The alternator is buggered and I drove the 40 miles with the lights on
yesterday so the battery wasnt fully charged. I'll check those things
pmc_3
posted on 23/1/05 at 08:38 PM |
The - one or the coil lead that goes to the dizzy cap?
Stu16v
posted on 23/1/05 at 09:22 PM |
To the dizzy body rather than the cap. Sorry...
pmc_3
posted on 23/1/05 at 10:02 PM |
Cheers Stu
pmc_3
posted on 24/1/05 at 07:31 PM |
Went down to the garage and put the battery back in. Got my dad to turn it over whilst I checked the points were sparking, which they were. Havent got
a multimeter but have a circuit tester and tested the positive to the coil and got a very bright light. Still no spark from the king lead of the coil.
Which points to the coil? The only worrying thing is the coil looks quite new.
Stu16v
posted on 24/1/05 at 07:48 PM |
Try a sprk plug lead into the end of the coil first. Might be a duff king lead...
Do you know if you have ballast ignition fitted? Quite important, becuase if you have a 9v coil fitted which is getting a 12v feed, they don't
tend to last for long...
pmc_3
posted on 24/1/05 at 10:26 PM |
I dont think I have the ballast system. I think there is just a direct feed from the battery to a switch in the cabin and then from that to the coil.
I tried a couple of different leads that I know work. Is it likely that the coil has snuffed it? The problem just seems weird because the car was
running fine when I put it away.
[Edited on 24/1/05 by pmc_3]
tks
posted on 25/1/05 at 01:19 PM |
try onother coil
they seem to be sensitibe once broke one
just sparking with the main lead to chasis...
measure the resistance of the coil, in that way you could measure if its in condition or not..
TKS
pmc_3
posted on 25/1/05 at 06:48 PM |
I'll try another coil, I think thats gonna be the culprit
pmc_3
posted on 25/1/05 at 09:43 PM |
The current coil doesnt say how many volts it is. It just says the brand which is Intermotor.
