ady8077
posted on 23/1/05 at 10:37 PM |
samco hose
Hi
Anyone no if its ok with petrol?
I'm thinking of using some to mount my throttle bodies
Adrian
Fozzie
posted on 23/1/05 at 11:48 PM |
Nope Samco is NOT OK with petrol
Fozzie
stevebubs
posted on 23/1/05 at 11:59 PM |
If you're after the bling factor samco gives you, just get some braided fuel hose with anodised end fittings...
Thinkauto should have what you want
ady8077
posted on 24/1/05 at 05:12 PM |
Thanks guys
I didn't think it was
Do Thinkauto do braded hose 54mm I/D ?
Adrian
cidersurfer
posted on 24/1/05 at 06:44 PM |
That gonna be high cost! It'd be interesting to know how much! What about black rubber petrol hose and tape wrap to look like samco? Just a
thought...
shimming solid lifters is a job for a friend...
ady8077
posted on 24/1/05 at 07:30 PM |
I'm not too botherd about looks, I only need 4 x 1" pieces to go between manifold and TB's
Adrian
stevebubs
posted on 24/1/05 at 09:45 PM |
Adrian
Ah... 2.25" fuel filler hose should fulfil your requirements....any of the usual motorsport / kit places should be able to supply that!
cidersurfer
posted on 24/1/05 at 09:59 PM |
Adrian
Adrian
I'm doing the same but with 44mm ID. Have ordered from Europa, but it's been over a week now and they still haven't got it in.
Chris
NS Dev
posted on 24/1/05 at 10:11 PM |
Who said Samco hose won't resist petrol............because it will!!!
Just use samco hose between the two, no problem. If you are really worried, get the fluorolined silicone hose that they do at a slightly higher cost,
this is even more fuel resistant.
rally design do it at very competitive prices (certainly cheaper than Europa)
BMF
posted on 26/1/05 at 01:50 PM |
Ring Highbury hose up and tell them what you want. They make it specifically for you and because you are going direct are about 40% cheaper than SAMCO
and look identical!
Tel. 01283 217750
NS Dev
posted on 26/1/05 at 03:42 PM |
oooh, nice one!
